Bar Support tip geometry
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've been playing around with Netfabb after getting fed up with support generation in Meshmixer. So far I have found it to be fairly good and relatively intuitive to use.
The support generator is seriously configurable and works quite well for auto-generation. My issue is the geometry of the bar support tips. I am using Netfabb exclusively for SLA printing and I liked the conical tip shape of the supports in Meshmixer. They worked really well and were very straight forward to configure.
In Netfabb, no matter how many different ways I have tried changing parameters around, the tip is a blob that projects out of the part and necks down (then back up to the post diameter). Is there any way to have just a standard conical tip of say 60 degrees included angle and 0.03 mm diameter contact point? I sort of got this effect by changing the offset from the part to a negative number, but this doesn't work close to an edge that I need to support where there is an undercut (thread) just below the surface.
