WPF - problem with images
Hi all,
I switched from WinForms to WPF recently and I have some problems with attachings images to a WPF window. To show my problem I have created a simple application. I have added the image (X_image.png) to the resources. In VS the application looks as shown below (everyting is fine, the image is visible in the centre of the window)
When I run the autocad and load the .dll file the image is not visible.
The code of the window
<Window x:Class="WpfAutoCadImageTest.UserControl1"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             xmlns:local="clr-namespace:WpfAutoCadImageTest"
             mc:Ignorable="d"
        Title="Test" Height="120.5" Width="187">
    <Grid>
        <Grid.ColumnDefinitions>
            <ColumnDefinition Width="*"/>
        </Grid.ColumnDefinitions>
        <Grid.RowDefinitions>
            <RowDefinition Height="*"/>
        </Grid.RowDefinitions>
        <Image Grid.Column="1" Grid.Row="1" Source="pack://siteoforigin:,,,/Resources/X_Image.png"></Image>
    </Grid>
</Window>
The code of the command
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
[assembly:CommandClass(typeof(WpfAutoCadImageTest.Class1))]
namespace WpfAutoCadImageTest
    public class Class1
        [CommandMethod("test",CommandFlags.Modal)]
        public void Run()
            UserControl1 u = new UserControl1();
            Application.ShowModalWindow(u);
Thank you for any suggestions.
Mch
BKSpurgeon
not the specific answer you are after, but those who are reading in the future, you may find this of some benefit:
http://adndevblog.typepad.com/autocad/2013/05/api-webcast-archive.html
SENL1362
1. Youre mixing a window and a UserControl;
2. You need a ElementHost(Form or PaletteSet) to show a UserControl in.
My advise it to examine this sample from our highly valued teacher Kean Walmsley (Norman Yuan also posted some samples on PaletteSet maintanance).
It shows you the necessary basic steps and the difference between directly addng a UserControl using ADDVISUAL and indirectly Adding a UserControl via a ElementHost using the ADD function.
http://through-the-interface.typepad.com/through_the_interface/2009/08/hosting-wpf-content-inside-an...
Then some personal advises:
- A thourough knowledge of WPF/XAML can be very helpful.
- Do not define exact sizes in XAML, let the User and thus the Palette size decide that, but you can define minimal values.
- Pay attension to the differences between PaletteSet, Palette, UserControl. A UserControl is shown in a Palette, Palette(s) are shown in a PaletteSet.
- Scaling and sizing the UserControl within he Palette can be confusing and often requires to set ps.Visible=true more than once as well as the Dock and DockEnabled functions to set correctly.
- complicated is the way to control UserControl buttons events by the callers.
SENL1362
This sample may help you to understand the usage of PaletteSet, Palette and WPF UserControl and save you some time to investigate the how and why of building these controls. I think each of of us has spent a lot of time to get these controls working.
The focus on this sample is on the interaction between AutoCAD and the UserControl, NOT on the Contents of the UserControl. That's subject for another Forum Threat.
The sample show how to encapsulate all the required actions for a PaletteSet into one class: PaletteSetMultiplePalettes
I'll show you how to add two Palettes(and UserControls) in the PaletteSet to let you better understand the relation between PaletteSet, Palette(s) and the UserControl(s).
Pay attension to the building of the PaletteSet, Palette and UserControl in the function ShowPaletteSet(..). The set Dock, Visible(3X) is crusial for having the contents scaled proparly whithin the Palettes. Also note that the UserControl size is not defined, only the minimal Sizes.
The Palettes are AutoCAD document independant, meaning that there is only one PaletteSet for the running AutoCAD session. The UserControls will be updated for each active document. This is done in the DocumentActivated event AND triggered by the Layers_CollectionChanged event.
Also shown is how the WPF button Events and WpfData is handled by the Parent Class using the ButtonClickedEventHandler. This promotes the reuse of the UserControls.
This sample is build for AutoCAD 2016. Previous versions of AutoCAD may handle the building of the PaletteSets a bit different in requirds to the Size (DeviceIndependentSize) properties.
For this sample required referenced are
- AcCoreMgd, AcDbMgd, AcMgd, AcCui, AcCustomize, adWindows.
- PresentationFramework, PresentationCore, Xaml.
- Windows Forms, WindowsFormsIntegration.
After Compile, autoload into AutoCAD using the registry or simply use NETLOAD.
The Palettes will be shown with the command: ShowPsM.
Notice the Tabs in the PaletteSet for each Palette/UserControl.
Then create or open another drawing and notice the contents of the Palette get updated.
Create Layers or Text Styles and again the Palettes will be updated.
Press one of the OK buttons and the WPF contents will be send to the ucControlX_OnOkClicked event and written to the CommandLine.
Press the Cancel button and the Palette/UserControl will be removed from the PaletteSet. When both UserControls are cancelled the PalettSet will be removed as well.
Note that this sample is A way tho handle PaletteSets/Palettes and UserControl, not THE way of doing this.
I hope that other Authors of this forum comment on this template to improve.
Good Luck.
All Usings, repeat this in the other modules below.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
using Autodesk.AutoCAD.Runtime;					//accoremgd, acdbmgd, acmgd
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.LayerManager;
using Autodesk.AutoCAD.PlottingServices;
using Autodesk.AutoCAD.Publishing;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Windows.ToolPalette;
// renamings
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using AcAp = Autodesk.AutoCAD.ApplicationServices;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcEd = Autodesk.AutoCAD.EditorInput;
using AcGe = Autodesk.AutoCAD.Geometry;
using AcRx = Autodesk.AutoCAD.Runtime;
using AcCm = Autodesk.AutoCAD.Colors;
using AcGi = Autodesk.AutoCAD.GraphicsInterface;
using AcLy = Autodesk.AutoCAD.LayerManager;
using AcPl = Autodesk.AutoCAD.PlottingServices;
using AcUi = Autodesk.AutoCAD.Windows;
using PlotType = Autodesk.AutoCAD.DatabaseServices.PlotType;
using AcWin = Autodesk.AutoCAD.Windows;
AcadApplication class: AcadInit
using System;
namespace AcadWpf
    public class AcadInit : IExtensionApplication
        public static DocumentCollection AcadDocMan = AcadApp.DocumentManager;
        public static Dictionary<string, Delegate> RefreshPaletteContent { get; set; }
        void IExtensionApplication.Terminate()
        void IExtensionApplication.Initialize()
            try
                AcadDocMan.DocumentActivated += AcadDocMan_DocumentActivated;
                AcadApp.UIBindings.Collections.Layers.CollectionChanged += Layers_CollectionChanged;
                //Each Palette has to add it's own Refresh Command, like:
                //public class PaletteSetMultiple
                //... InfraApp.RefreshPaletteContent["PsMultiple"] = new Func<Document, bool>(RefreshPaletteContents);
                //...   public static bool RefreshPaletteContents(Document doc)
                RefreshPaletteContent = new Dictionary<string, Delegate>(StringComparer.OrdinalIgnoreCase);
            catch  //(System.Exception ex)
                //throw;
        void Layers_CollectionChanged(object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs e)
            var doc = AcadApp.DocumentManager.MdiActiveDocument;
            if (doc != null)
                PaletteSetMultiplePalettes.RefreshPaletteContents(doc);
        void AcadDocMan_DocumentActivated(object sender, DocumentCollectionEventArgs e)
            Document doc = e.Document;
            if (doc == null)
                return;
            //Active Document is changed, refresh PaletteContent for visible PaletteSets
            foreach (var paletteNameToRefresh in RefreshPaletteContent.Keys)
                RefreshPaletteContent[paletteNameToRefresh].DynamicInvoke(doc);
PaletteSet/Palette Handler Class
using System;
namespace AcadWpf
    public class PaletteSetMultiplePalettes
        private static PaletteSet PsMultiple;
        private static Palette Puc1;
        private static Palette Puc2;
        private static UserControl1 ucControl1;
        private static UserControl2 ucControl2;
        public PaletteSetMultiplePalettes(Document doc = null)
            ShowPaletteSet(doc);
        private static bool ShowPaletteSet(Document doc = null)
            if (PsMultiple == null)
                if (ucControl1 == null)
                    ucControl1 = new UserControl1();
                    ucControl1.OnOkClicked += ucControl1_OnOkClicked;
                    ucControl1.OnCancelClicked += ucControl1_OnCancelClicked;
                if (ucControl2 == null)
                    ucControl2 = new UserControl2();
                    ucControl2.OnOkClicked += ucControl3_OnOkClicked;
                    ucControl2.OnCancelClicked += ucControl2_OnCancelClicked;
                PsMultiple = new PaletteSet("PsMultiple", "ShowPsM", new Guid("81BE7D63-5FA9-4CA5-9418-7830CA53B766"));
                PsMultiple.Dock = DockSides.None;
                PsMultiple.DockEnabled = DockSides.None;
                Puc1 = PsMultiple.AddVisual("Control1", ucControl1, true);
                Puc2 = PsMultiple.AddVisual("Control2", ucControl2, true);
                //Now the Control Is Added the ActualSize becomes available, and thus the best Palette(Set) size can be calculated
                // Note the Palette need not to be visible.
                var minPsWidth = (ucControl1.ActualWidth > ucControl2.ActualWidth) ? ucControl1.ActualWidth : ucControl2.ActualWidth;
                var minPsHeight = (ucControl1.ActualHeight > ucControl2.ActualHeight) ? ucControl1.ActualHeight : ucControl2.ActualHeight;
                //This Visible call must be executed several times in order to have the PaletteSet, Palette or it's Tabs to become visible
                PsMultiple.Visible = true;
                //Add a few units because the Palette(Set) need a bit more space than it's contents
                minPsWidth += 120;
                minPsHeight += 40;
                PsMultiple.MinimumSize = new System.Drawing.Size((int)minPsWidth, (int)minPsHeight);
                //Now centre te Palette into the AutoCAD Window.
                var appWinPos = AcadApp.MainWindow.DeviceIndependentLocation;
                var appWinSize = AcadApp.MainWindow.DeviceIndependentSize;
                var xAppCenter = appWinPos.X + 0.5 * appWinSize.Width;
                var yAppCenter = appWinPos.Y + 0.5 * appWinSize.Height;
                PsMultiple.DeviceIndependentSize = new System.Windows.Size(minPsWidth - 200, minPsHeight - 150);
                PsMultiple.DeviceIndependentLocation = new System.Windows.Point(xAppCenter - 0.5 * PsMultiple.DeviceIndependentSize.Width, yAppCenter - 0.5 * PsMultiple.DeviceIndependentSize.Height);
            //Register the RefreshCommand to be executed when AutoCAD changes it's active document
            AcadInit.RefreshPaletteContent["PsMultiple"] = new Func<Document,bool>(RefreshPaletteContents);
            return true;
            if (PsMultiple == null || !PsMultiple.Visible)
                return false;
            if (doc == null)
                return false;
            if (ucControl1 != null)
                ucControl1.ShowData(doc);
            if (ucControl2 != null)
                ucControl2.ShowData(doc);
            return true;
        [CommandMethod("ShowPsM")]
        public static void ShowPaletteSetMultiple()
            Document doc = null;
            Database db = null;
            Editor ed = null;
            try
                if (doc == null)
                    throw new System.Exception("No MdiActiveDocument");
                db = doc.Database;
                ed = doc.Editor;
            catch (System.Exception ex)
                if (ed != null)
                    ed.WriteMessage("\n Error: ShowPaletteSetMultiple: {0}", ex.Message);
                else
                    System.Windows.Forms.MessageBox.Show(ex.Message, "ShowPaletteSetMultiple", System.Windows.Forms.MessageBoxButtons.OK);
        private static void ucControl1_OnCancelClicked(object sender, EventArgs e)
            ucControl1.OnOkClicked -= ucControl1_OnOkClicked;
            ucControl1.OnCancelClicked -= ucControl1_OnCancelClicked;
            ucControl1 = null;
            Puc1 = null;
            //Note: the current one is always index=0
            PsMultiple.Remove(0);
                PsMultiple.Visible = false;
                PsMultiple.Close();
                PsMultiple = null;
            System.Windows.Forms.Application.DoEvents();
        private static void ucControl1_OnOkClicked(object sender, EventArgs e)
            var text = ucControl1.LayerText;
            Document doc = AcadApp.DocumentManager.MdiActiveDocument;
            if (doc != null)
                Editor ed = doc.Editor;
                ed.WriteMessage("\n TextBlock: {0}", text);
        private static void ucControl2_OnCancelClicked(object sender, EventArgs e)
            //Puc2 = null;
            ucControl2.OnOkClicked -= ucControl3_OnOkClicked;
            ucControl2.OnCancelClicked -= ucControl2_OnCancelClicked;
            ucControl2 = null;
            Puc2 = null;
                PsMultiple.Close();
                PsMultiple = null;
        private static void ucControl3_OnOkClicked(object sender, EventArgs e)
            var text = ucControl2.StyleNames;
            if (doc != null)
<UserControl x:Class="AcadWpf.UserControl1"
             mc:Ignorable="d" Height="auto" Width="auto" MinHeight="120" MinWidth="400" d:DesignHeight="300" d:DesignWidth="400">
    <Grid Background="White" >
            <RowDefinition Height="2*"/>
            <RowDefinition Height="1*" MinHeight="30" MaxHeight="50" />
            <ColumnDefinition Width="3*" />
            <ColumnDefinition Width="1*" MinWidth="100"/>
        <Grid  Grid.Row="0" Grid.Column="0"  >
            <TextBlock Name="tbkLayers"  Text="{Binding LayerText}" HorizontalAlignment="Stretch" VerticalAlignment="Stretch"  Margin="5" TextWrapping="Wrap" />
        </Grid>
        <Grid  Grid.Row="1" Grid.ColumnSpan="2" >
            <StackPanel Orientation="Horizontal" HorizontalAlignment="Right" Margin="5" >
                <Button  Name="btnOk" Content="OK"  MinWidth="100" MaxWidth="150"  Margin="5"  Click="btnOk_Click"/>
                <Button  Name="btnCancel" Content="Cancel"  MinWidth="100" MaxWidth="150"   Margin="5" IsCancel="True"   Click="btnCancel_Click"/>
            </StackPanel>
        </Grid>
    </Grid>
</UserControl>
Using System;
namespace AcadWpf
    /// <summary>
    /// Interaction logic for UserControl1.xaml
    /// </summary>
    public partial class UserControl1 : UserControl
       public delegate void ButtonClickedEventHandler(object sender, EventArgs e);
        public event ButtonClickedEventHandler OnOkClicked;
        public event ButtonClickedEventHandler OnCancelClicked;
        public string LayerText { get; private set; }
        public UserControl1()
            InitializeComponent();
            //No Binding for TextBlock.  tbkLayers.ItemsSource = LayerText;
        private void OnOkBtnClicked(object sender, EventArgs e)
            // Delegate the event to the caller
            if (OnOkClicked != null)
                OnOkClicked(this, e);
        private void OnCancelBtnClicked(object sender, EventArgs e)
            if (OnCancelClicked != null)
                OnCancelClicked(this, e);
        public bool ShowData(Document doc)
            if (doc == null)
                return false;
            Database db = doc.Database;
            string docData = this.GetType().Name + ": Show Layer Data for: " + doc.Name + Environment.NewLine;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                var layerTable = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
                docData += " Layers: " + layerTable.Cast<ObjectId>().Count() + Environment.NewLine;
                foreach (var lyId in layerTable)
                    var layer = (LayerTableRecord)tr.GetObject(lyId, OpenMode.ForRead);
                    docData += "    " + layer.Name + Environment.NewLine;
                tr.Commit();
            tbkLayers.Text = docData; //Binding doesn't seems to work for TextBlocks
            btnCancel.Click -= new System.Windows.RoutedEventHandler(OnCancelClicked);
            btnCancel.Click += new System.Windows.RoutedEventHandler(OnCancelClicked);
            btnOk.Click -= new System.Windows.RoutedEventHandler(OnOkClicked);
            btnOk.Click += new System.Windows.RoutedEventHandler(OnOkClicked);
            return true;
        private void btnOk_Click(object sender, RoutedEventArgs e)
            LayerText = tbkLayers.Text;
        private void btnCancel_Click(object sender, RoutedEventArgs e)
            LayerText = null;
<UserControl x:Class="AcadWpf.UserControl2"
            <TextBlock Name="tbkStyles"  Text="{Binding StyleNames}" HorizontalAlignment="Stretch" VerticalAlignment="Stretch"  Margin="5" TextWrapping="Wrap" />
        </Grid>
            </StackPanel>
        </Grid>
    </Grid>
</UserControl>
Using System;
namespace AcadWpf
    /// <summary>
    /// Interaction logic for UserControl2.xaml
    /// </summary>
    public partial class UserControl2 : UserControl
        public string StyleNames{ get; private set; }
        public UserControl2()
            //this.DataContext = this;
            if (doc == null)
                return false;
            string docData = this.GetType().Name + ": Show TextStyle Data for: " + doc.Name + Environment.NewLine;
                var textStyleTable = (TextStyleTable)tr.GetObject(db.TextStyleTableId, OpenMode.ForRead);
                docData += " TextStyles: " + textStyleTable.Cast<ObjectId>().Count() + Environment.NewLine;
                foreach (var styleId in textStyleTable)
                    var txtStyle = (TextStyleTableRecord)tr.GetObject(styleId, OpenMode.ForRead);
                    docData += "    " + txtStyle.Name + Environment.NewLine;
                tr.Commit();
            tbkStyles.Text = docData; //Binding doesn't seems to work for TextBlocks
            return true;
            StyleNames = tbkStyles.Text;
            StyleNames = null;
norman.yuan
While otherreplies  (SENL 1362...) provided much useful information, here is mine more directly to your issue of image not showing at runtime with WPF UI, which I ran into recently.
In my case, I used a WPF UserControl in a PaletteSet. iin the UserControl, I needed to use either ribbon menu, or WPF menu/toolbar, and I eventually chose WPF toolbar. The to save space, the toolbar button would only show image without text (just line a regular toolbar button). I used the same XAML syntext for the image, as you did:
well, I used "pack://siteoforigin:..." to "pack://[application_name]:...". then I make sure in the "Properties" window all th eimages are set to compile as "Resources"
At design time, the images show correctly on the toolbar button. However, when the Paletteset in shown in AutoCAD, the images do not show. BY the way, if I use the same WPF UserControl in a WPF exe app, the toolbar button images show correctly. I use AutoCAD 2015 and VS2013.
I did not have time to try all possible scenarios, such as in modal window (as you did), or model window, or different version of AutoCAD, Visual Studio..., but my solution, as it tured out, was rather simple: simply use the "hard path" as the image source. That is:
<Image Source="..\Resources\JobOdTable.png" Stretch="None"></Image>
Here, the folder "Resources" is created by VS when you add images to the project's Resources. and you may sure images are built as "Resources" not "Content' (default).
With this image source setting, the toolbar button's images in the WPF UserControl are shown both in design time and runtime, and all the images are compiled intn DLL as resources (thus, no extra folder of images to be outputted for deployment).
Norman Yuan
Drive CAD With Code
Keith.Brown
I agree with Norman and it is probably how you path your images and if they are set to content or to a Resource.  Here is a link to a project where I have added the images to my project just by dragging them into a folder in visual studio.  I then set the images to compile as a Resource.  The link to download the project is at the bottom of the first post.
http://forums.autodesk.com/t5/net/set-f1-help-contents-using-a-custom-wpf-ribbon-with-xaml/m-p/59070...
F.Y.I  in my own development i usually place the images in their own DLL.  I have noticed that in using WPF that even though I place the dll in the same directory the DLL needs to be netloaded in order for the images to appear.  If i access any code in the image dll then it will automatically be loaded by AutoCAD.  But if i only access the image resource then I must netload the dll.
Thank you for your replies. The solustion with hard path works, however, only on computer with VS.
The proper solution is:
<Image Grid.Column="1" Grid.Row="1" Source="pack://application:,,,/dllName;component//Resources/X_Image.png"></Image>
where dllName is the name os your dll file.
Regards
Michal
