.NET
Visual Studio 2017 with AutoCAD Map 3D 2016
3 REPLIES 3
Markus_Strauss
856 Views, 3 Replies
We had to resetup our computer so we installed the Developer Studio 2017 (instead of 2015 before).
I can compile it for AutoCAD Map 3D 2016 till before. (and execute it).
Before it was possible to start AutoCAD 2016 automatic to debug it (and connect to the process).
Now i have to start acad manual and connect to the running process(to debug). When I do it like before The AutoCAD Application crashes (little window telling me "AutoCAD Application funktioniert nicht mehr Es wird nach einer Lösung für das Problem gesucht..." with a canel button - After a longer period of time AutoCAD Closes itselfe).
Beside AutoCAD Map 3D 2016 we install the 2018 version to upgrade our code while we still can fix bugs in the current version of our code.
3 REPLIES 3
_gile
in reply to: Markus_Strauss
I do not use MAP and have not installed VS2017 yet, but there's a known issue with non English versions of AutoCAD MAP and Visual Studio, see:
https://knowledge.autodesk.com/support/autocad-map-3d/troubleshooting/caas/sfdcarticles/sfdcarticles...
Gilles Chanteau
GileCAD
GitHub
Markus_Strauss
in reply to: _gile
Thx a lot - this solved my Problem!
Thanks for Sharing this URL. Very Helpful!
AutoCAD Inside the Factory
