Viewport size
Viewport size
p.zwiers
Viewport size
p.zwiers
Hi All,
Lately i've been working on a VB.net script to loop through all my large viewports and do a zoomextents on the content of this viewport. during this zoomextents the new scale will round up. for example 1:21,433 will be 1:30.
Because of this i want to resize my viewport to the new scale of my viewport with some space around. When i apply the code below (so resize the viewport with the vp.width and vp.height) the visible border of my viewport will not change in the lay-out. though when i look in the viewport properties itself the dimensions are changed.
So the question is; why does the viewport border does not update after changing the dimensions?
Module PaperSpace
    Public Sub PrepareLayouts()
        Dim Newdoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = Newdoc.Database
        Dim ed As Editor = Newdoc.Editor
        Dim lm As LayoutManager = LayoutManager.Current
        Using tr As Transaction = db.TransactionManager.StartTransaction()
            'Loop thru the layouts making each one active
            Dim layoutDict As DBDictionary = db.LayoutDictionaryId.GetObject(OpenMode.ForRead)
            Dim modelMin2D As Point2d = New Point2d(db.Extmin.X, db.Extmin.Y)
            Dim modelMax2D As Point2d = New Point2d(db.Extmax.X, db.Extmax.Y)
            Dim modelWidth As Double = db.Extmax.X - db.Extmin.X
            Dim modelHeight As Double = db.Extmax.Y - db.Extmin.Y
            For Each de As DBDictionaryEntry In layoutDict
                Dim layout As Layout = de.Value.GetObject(OpenMode.ForRead)
                Dim layoutName As String = layout.LayoutName
                If layoutName <> "Model" Then
                    'Loop thru layout viewports for zoom extents
                    lm.CurrentLayout = layoutName
                    Dim vpIdCol As ObjectIdCollection = layout.GetViewports()
                    For Each vpId As ObjectId In vpIdCol
                        Dim vp As Viewport = vpId.GetObject(OpenMode.ForWrite)
                        If (vp.Layer = "Viewport" Or vp.Layer = "Viewport Visible") And layout.PlotPaperSize.X / vp.Width < 1 Then
                            Dim vpWidth As Double = vp.Width
                            Dim vpHeight As Double = vp.Height
                            Dim scale As Integer = DefineScale(modelWidth / vpWidth)
                            vp.UpgradeOpen()
                            ''Zoom viewport to extents of model
                            vp.Width = modelWidth / scale
                            vp.Height = modelHeight / scale
                            vp.CenterPoint = New Point3d(vp.CenterPoint.X, vp.CenterPoint.Y + 15, vp.CenterPoint.Z)
                            vp.UpdateDisplay()
                            vp.Locked = False
                            vp.ViewCenter = modelMin2D + ((modelMax2D - modelMin2D) * 0.5)
                            vp.CustomScale = 1 / scale
                            vp.Locked = True
                            ''Perform actions on viewport layers
                            VPLayerFreeze(tr, layoutName, vp)
                            VPLayerGrey(tr, layoutName, vp)
                    Next
            Next
            tr.Commit()
            Newdoc.Editor.Regen()
            lm.CurrentLayout = "Model"
        End Using
    End Sub
moogalm
Autodesk Support
Autodesk Support
Can you please share the test drawing ?, and also definitions for these methods
  • VPLayerFreeze(tr, layoutName, vp)
  • VPLayerGrey(tr, layoutName, vp)
if this applicable to your routine. I would like to investigate the problem.
