Block Attribute value
cihanbaki2147
cihanbaki2147
I want to put the data in the block inside the block into a variable and use it in mathematical operations.
fieldguy
What have you tried so far?  There are several examples in this forum
https://forums.autodesk.com/t5/net/change-block-attribute/m-p/2996912#M23313
cihanbaki2147
You could share the c # code.
fieldguy
You could convert it yourself and learn something along the way?
http://converter.telerik.com/
stefan.hofer
Read Attributes...
//using acApp = Autodesk.AutoCAD.ApplicationServices.Application;
private void GetAttributeValues()
    Document doc = acApp.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    TypedValue[] acTypValAr = new TypedValue[1];
    acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "INSERT"), 0);
    SelectionFilter acSelFtr = new SelectionFilter(acTypValAr);
    using (Transaction acTrans = db.TransactionManager.StartTransaction())
        PromptSelectionResult acSSPrompt;
        acSSPrompt = ed.SelectAll(acSelFtr);
        if (acSSPrompt.Status == PromptStatus.OK)
            SelectionSet acSSet = acSSPrompt.Value;
            foreach (SelectedObject acSSObj in acSSet)
                if (acSSObj != null)
                    BlockReference br = (BlockReference)acTrans.GetObject(acSSObj.ObjectId, OpenMode.ForRead);
                    if (br != null)
                        AttributeCollection attCol = br.AttributeCollection;
                        foreach (ObjectId attId in attCol)
                            AttributeReference attRef = (AttributeReference)acTrans.GetObject(attId, OpenMode.ForRead);
                            ed.WriteMessage("Attribute Tag: " + attRef.Tag + "   |   Attribute Text: " + attRef.TextString + "\n");
        acTrans.Commit();
For dynamic blocks properties...
                    if (br != null && br.IsDynamicBlock)
                        DynamicBlockReferencePropertyCollection pc = br.DynamicBlockReferencePropertyCollection;
                        foreach (DynamicBlockReferenceProperty prop in pc)
                            ed.WriteMessage("Property name: " + prop.PropertyName + "   |   Property value: " + prop.Value + "\n");
