.NET
viewing window in autocad with .net
2 REPLIES 2
402 Views, 2 Replies
is there a control to add a viewing window in a dialog so that the it shows a drawing such as a rectangle in the viewing window as you change the width and height in the dialog.
2 REPLIES 2
Thank you for the responce, what i am hoping to do is create an interactive viewing window that will work in a dialog, for example i can create a dialog and have a width and length field and show the rectangle in the viewing window, and have more than one rectangle, in the window i need to be able to select one of the rectangles and change the entries into the field input boxes in dialog and have it update the rectangle in the viewing window. is it better to do this outside of .net with a custom control?
AutoCAD Inside the Factory
