I just saw your post looking for something - not sure if you have found a solution, but here is something that may help (in c# though). there are a few sites that can translate for you
static public void ApplyColourOverride()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
// Collection of our selected entities and their sub-ent paths
ObjectIdCollection ids;
List<FullSubentityPath> paths;
// Flag for whether a REGEN will be required
bool regenRequired = false;
// Start a transaction... will initially be used
// to highlight the selected entities and then to
// modify their color
Transaction tr = doc.TransactionManager.StartTransaction();
using (tr)
if (SelectNestedEntities(ed, out ids, out paths) &&
ids.Count > 0)
// Get the new color index
Autodesk.AutoCAD.Windows.ColorDialog cd = new ColorDialog();
System.Windows.Forms.DialogResult res = cd.ShowDialog();
if (res == System.Windows.Forms.DialogResult.OK)
for (int i = 0; i < ids.Count; i++)
Entity ent = tr.GetObject(ids[i], OpenMode.ForWrite) as Entity;
if (ent != null)
regenRequired = true;
//get the layer name
string layerName = ent.Layer;
LayerTable lt = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
LayerTableRecord ltr = (LayerTableRecord)tr.GetObject(lt[layerName], OpenMode.ForWrite);
LayerViewportProperties lvpo = ltr.GetViewportOverrides(ed.CurrentViewportObjectId);
lvpo.Color = cd.Color;
//ent.ColorIndex = pir.Value;
else if (res == System.Windows.Forms.DialogResult.Cancel)
UnhighlightSubEntities(paths);
tr.Commit();
// Regen reflects the new color
if (regenRequired)
ed.Regen();
static public void ApplyLinetypeOverride()
using (tr)
ids.Count > 0)
Autodesk.AutoCAD.Windows.LinetypeDialog cd = new LinetypeDialog();
if (ent != null)
lvpo.LinetypeObjectId = cd.Linetype;
tr.Commit();
if (regenRequired)
ed.Regen();
static public void ApplyLineweightOverride()
using (tr)
ids.Count > 0)
Autodesk.AutoCAD.Windows.LineWeightDialog cd = new LineWeightDialog();
if (ent != null)
lvpo.LineWeight = cd.LineWeight;
tr.Commit();
if (regenRequired)
ed.Regen();
private static bool SelectNestedEntities(Editor ed, out ObjectIdCollection ids, out List<FullSubentityPath> paths)
ids = new ObjectIdCollection();
paths = new List<FullSubentityPath>();
// Loop until cancelled or completed
PromptNestedEntityResult rs;
PromptNestedEntityOptions pneo = new PromptNestedEntityOptions("\nSelect nested entity: ");
pneo.AllowNone = true;
do
rs = ed.GetNestedEntity(pneo);
if (rs.Status == PromptStatus.OK)
ids.Add(rs.ObjectId);
FullSubentityPath path = HighlightSubEntity(rs);
if (path != FullSubentityPath.Null)
paths.Add(path);
while (rs.Status == PromptStatus.OK);
// Return whether the function was cancelled
return (rs.Status != PromptStatus.Cancel);
private static void UnhighlightSubEntities(List<FullSubentityPath> paths)
for (int i = 0; i < paths.Count; i++)
ObjectId[] ids = paths[i].GetObjectIds();
Entity ent = ids[0].GetObject(OpenMode.ForRead) as Entity;
if (ent != null)
ent.Unhighlight(paths[i], false);
private static FullSubentityPath HighlightSubEntity(PromptNestedEntityResult rs)
// Extract relevant information from the prompt object
ObjectId selId = rs.ObjectId;
List<ObjectId> objIds = new List<ObjectId>(rs.GetContainers());
// Reverse the "containers" list
objIds.Reverse();
// Now append the selected entity
objIds.Add(selId);
// Retrieve the sub-entity path for this entity
SubentityId subEnt = new SubentityId(SubentityType.Null, System.IntPtr.Zero);
FullSubentityPath path = new FullSubentityPath(objIds.ToArray(), subEnt);
// Open the outermost container, relying on the open
// transaction...
Entity ent = objIds[0].GetObject(OpenMode.ForRead) as Entity;
// ... and highlight the nested entity
if (ent == null)
return FullSubentityPath.Null;
ent.Highlight(path, false);
// Return the sub-entity path for later unhighlighting
return path;
I hope this helps.
