Using net6.0
Using net6.0
pierre.plaissy
Using net6.0
pierre.plaissy
I am trying to make a plugin using net6.0 instead of the usual net framework 4.8. (on Autocad Architecture 2022).
I can see on the command line that the plugin is loading correctly (at least without visible error), but it does not boot on the Initialize method and the commands are not loaded.
If anyone has an idea that would be great.
_gile
You cannot use .NET Core for AutoCAD plugins, you have to use the .NET framework.
Gilles Chanteau
GileCAD
GitHub
pierre.plaissy
thank you Gilles,
I suspected it but was surprised to see that there was no error loading.
Fortunately, according to Madhukar Moogala's answer (at the end of the blog post below), this may soon be possible...
https://adndevblog.typepad.com/autocad/2020/05/autocad-2021-net-api-on-nuget.html
