Announcements
Update dynamic nested block parameter
robert_lundbergVQD7E
I have a dynamic parent block lets call it A1, In A1's block definition i have multiple dynamic nested blocks lets call these B1,B2,B3,B4. Each of these nested blocks have their own Visibility Parameter and States. When i place A1 into a drawing i want to be able to change the visibility states of B1,B2.... What i have working now is A1 is being placed into the model space and i try to go over the entities inside the A1 block reference to find the nested block references with a "Visibility" Parameter. This all works and i have comboboxes in a windows forms for each nested block where the user can choose what visibility state should be active when inserting into the drawing. My problem is that the visibility of B1,B2.... are being changed for all instances of A1 in the drawing. So if i Have 3 A1's in the model space and i want to insert a new A1 with new visibility states for B1,B2.... the visibility states are also changed for the 3 other A1's already in the drawing.
So is it possible to access the nested block reference for a specific A1 instance in model space, instead of accessing what seems to be the B1, B2.... definition inside A1 ?
Replies (0)
Type a product name
