.NET
update atribute blok excel file
6 REPLIES 6
cihanbaki2147
485 Views, 6 Replies
I want to update the attributes in the export block of the excel file how can I do it
6 REPLIES 6
You can get the cell-value with this example:
        using excel = Microsoft.Office.Interop.Excel;
private void MyFunction() { string myValue = GetValuesFromExcelFile(@"c:\myfile.xls", "Z08"); //update the attribute with this value... } private string GetValuesFromExcelFile(string file, string key) { string result = ""; excel.Application oex = new excel.Application(); if (oex == null) { MessageBox.Show("Excel is not properly installed!!"); return result; } excel.Workbook owb = null; excel.Worksheet ows = null; try { owb = oex.Workbooks.Open(file, Type.Missing, true, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing); } catch { MessageBox.Show("Can't open file."); oex.Quit(); try { if (oex != null) Marshal.ReleaseComObject(oex); } catch { } return result; } ows = (excel.Worksheet)owb.Worksheets[1]; bool found = false; string valueCol = "B"; excel.Range keyCellRange = ows.get_Range("A2", "A24"); try { foreach (excel.Range r in keyCellRange) { if (r.Value2 != null) { if (r.Value2 == key) { string valueCell = valueCol + r.Row.ToString(); excel.Range valueCellRange = ows.get_Range(valueCell); if (valueCellRange.Value2 != null) { result = valueCellRange.Value2.ToString(); found = true; break; } } } } if (!found) { MessageBox.Show("Key or Value not found... " + key); } } catch (Exception ex) { MessageBox.Show("Error: " + ex.Message); } finally { owb.Close(true, Type.Missing, Type.Missing); oex.Quit(); try { if (ows != null) Marshal.ReleaseComObject(ows); if (owb != null) Marshal.ReleaseComObject(owb); if (oex != null) Marshal.ReleaseComObject(oex); } catch { } } return result; }
I am copying the codes into the button and it gives an error how to solve it
dbhunia
in reply to: cihanbaki2147
place only..
inside button6_click()......
And create another function seperately..........
string result = "";
return result;
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
the complete solution with comments...
on the top of you file add:
using System;
using System.Collections.Generic;
using System.Runtime.InteropServices;
using System.Windows.Forms;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using acApp = Autodesk.AutoCAD.ApplicationServices.Application;
your button click event:
        private void button28_Click(object sender, EventArgs e)
            MyFunction();
the main function:
            string myExcelFile = @"c:\myfile.xlsx";
            string myKey = "Z08";
            //Get the value from the excel file (find the cell with the key, and return the value)
            string myValue = GetValuesFromExcelFile(myExcelFile, myKey);
            //Update the block attributes with the new value...
            SetBlockAttributeValue(myKey, myValue);
the void to set a new attribute value: (used in the main function)
        private void SetBlockAttributeValue(string key, string value)
            Document doc = acApp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            List<string> editInformations = new List<string>();
            //Set the selection filter
            TypedValue[] acTypValAr = new TypedValue[1];
            acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "INSERT"), 0);
            SelectionFilter acSelFtr = new SelectionFilter(acTypValAr);
            //Select all blocks (INSERT) in the drawing
            PromptSelectionResult acSSPrompt;
            acSSPrompt = ed.SelectAll(acSelFtr);
            //If the selection OK
            if (acSSPrompt.Status == PromptStatus.OK)
                //Lock the document
                using (DocumentLock acLckDoc = doc.LockDocument())
                    //Add the selected blocks to a selection set
                    SelectionSet acSSet = acSSPrompt.Value;
                    using (Transaction acTrans = db.TransactionManager.StartTransaction())
                        //Check all blocks
                        foreach (SelectedObject acSSObj in acSSet)
                            if (acSSObj != null)
                                //Open the block reference
                                BlockReference br = acTrans.GetObject(acSSObj.ObjectId, OpenMode.ForRead) as BlockReference;
                                //Get the attribute collection
                                AttributeCollection attCol = br.AttributeCollection;
                                //Check all attributes in the block
                                foreach (ObjectId attId in attCol)
                                    AttributeReference attRef = (AttributeReference)acTrans.GetObject(attId, OpenMode.ForWrite);
                                    if (attRef != null)
                                        //If the attribute-tag is your key...
                                        if (attRef.Tag == key)
                                            //Save informations...
                                            editInformations.Add("Block name: " + br.Name + " | Key: " + key + " | Old Value: " + attRef.TextString + " | New Value: " + value);
                                            //Set the new attribut value
                                            //attRef.UpgradeOpen();
                                            attRef.TextString = value;
                                            //attRef.DowngradeOpen();
                                }//end foreach attId
                        }//end foreach acSSObj
                        //Apply changes...
                        acTrans.Commit();
                    }//end acTrans
                    acSSet.Dispose();
                }// end document lock
            }//end acSSPromt.Status OK
            //Show informations in the command line
            if (editInformations.Count > 0)
                ed.WriteMessage("Total " + editInformations.Count.ToString() + " attributes changed" + System.Environment.NewLine);
                foreach (string editinfo in editInformations)
                    ed.WriteMessage(editinfo + System.Environment.NewLine);
            else
                MessageBox.Show("No attributes found...");
the void to get the value from excel file: (used in the main function)
            //Start with a empty result...
            string result = "";
            //Set the excel application
            //If excel not found, show info dialog
            if (oex == null)
                return result;
            //Open the excel workbook (document)
            try
            catch
                oex.Quit();
                try
                    if (oex != null)
                catch { }
                return result;
            //Set the excel document sheet (1 = first sheet)
            bool found = false;
            //Column in the sheet with the value
            //The range to search for the key (Cell A2 - A24)
            try
                    //Check if the cell is (not) empty
                        //if the cell is your key...
                            //Get the cell with the value...
                            //If the cell is (not) empty
                                //Get the cell value
                                //We found something...
                                found = true;
                                //Exit the foreach loop... no reason to check more cells.
                                break;
                if (!found)
                    //No cell with the key found
                    MessageBox.Show("Key not found... " + key);
            finally
                //Close the workbook and the excel application
                oex.Quit();
                try
                    if (ows != null)
                    if (owb != null)
                    if (oex != null)
                catch { }
            return result;
it's tested, and it works.
thanks for the useful information you shared aderim kodta gave such an error
i only adivce... you did not add the reference.
Read this: https://docs.microsoft.com/en-us/dotnet/csharp/programming-guide/interop/how-to-access-office-ontero...
The second Title "To add referneces" -> add Microsoft.Office.Interop.Excel
Technology Administrators
