TranslateCoordinates to DCS .NET C#\VB
Hello. I wanted to convert the coordinates of 2 points. I used this method once ...
Dim point1DCS() As Double = AcadApp.ActiveDocument.Utility.TranslateCoordinates(pt1, AcCoordinateSystem.acWorld, AcCoordinateSystem.acDisplayDCS, False)
Anyone know how to get this effect in NET API?
Ed__Jobe
You can still use that if you reference the ActiveX api using Autodesk.AutoCAD.Interop
Ed
How to post your code.
_gile
With plain .NET, you can use the following extension methods.
would be:
Point3d point1DCS = pt1.TransformBy(ed.WCS2DCS());
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using System;
namespace AutoCadUtilsLibrary
    public static class Extension
        public static Matrix3d EyeToWorld(this AbstractViewTableRecord view)
            if (view == null)
                throw new ArgumentNullException("view");
            return
                Matrix3d.Rotation(-view.ViewTwist, view.ViewDirection, view.Target) *
                Matrix3d.Displacement(view.Target.GetAsVector()) *
                Matrix3d.PlaneToWorld(view.ViewDirection);
        public static Matrix3d WorldToEye(this AbstractViewTableRecord view)
            if (view == null)
            return
                Matrix3d.WorldToPlane(view.ViewDirection) *
                Matrix3d.Displacement(view.Target.GetAsVector().Negate()) *
                Matrix3d.Rotation(view.ViewTwist, view.ViewDirection, view.Target);
        public static Matrix3d DCS2WCS(this Editor ed)
            if (ed == null)
                throw new ArgumentNullException("ed");
            using (ViewTableRecord view = ed.GetCurrentView())
                return view.EyeToWorld();
        public static Matrix3d WCS2DCS(this Editor ed)
            if (ed == null)
                return view.WorldToEye();
Gilles Chanteau
GileCAD
GitHub
