.NET
Transform Region
2 REPLIES 2
SRSDS
258 Views, 2 Replies
Transform Region
I need regions from an xreference.
How can I transform them to the WCS?
region.TransformBy(XrefTransformMatrix) doesn't give a value.
edit: I'm guessing I need to change it to a polyline, transform the polyline, then convert it back to a region.
I need to deterimine if the region contains a point using brep
2 REPLIES 2
_gile
in reply to: SRSDS
Wouldn't it be simpler to transform the point with the inverse transformation matrix?
Gilles Chanteau
GileCAD
GitHub
SRSDS
in reply to: SRSDS
Thank you. Yep. 🙂
AutoCAD Inside the Factory
