Solved by Daniel.Du. Go to Solution.
Have you ever been here?
http://www.autodesk.com/developautocad
http://www.autodesk.com/developinventor
Part of the problem is those classes do not talk about how to structure "libraries" of things.
This matters because you would want to reuse as much as possible, and avoid duplicate code with minor tweaks for different target versions.
So getting used to .net itself must be done in order to make the cad programming smooth.
I can explain how I organize things if needed, I am always looking for better ways myself.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
