.NET
TaskDialog - Can't disable cancellation
2 REPLIES 2
BMcAnney
462 Views, 2 Replies
I'm using TaskForms (Autodesk.Windows.TaskForm), and it's all working pretty well, with one exception. I can't seem to disallow cancellation of the taskform. The class has a property called AllowDialogCancellation, but regardless of what I set that to the dialog still has a clickable X, and can also be closed with the escape key. Does anyone know where I'm going wrong?
Thanks!
Brent McAnney
2 REPLIES 2
BMcAnney
in reply to: BMcAnney
Sorry, where I say TaskForm above, I meant to say TaskDialog (Autodesk.Windows.TaskDialog).
BMcAnney
Well, I figured it out. Sort of. This happens as soon as I add a second button to the form. If I comment out the second button definition, everything works great, but as soon as I add a second button, the form becomes cancellable.
This works:
td.UseCommandLinks = True
td.Buttons.Add(New TaskDialogButton(1, "Continue"))
td.DefaultButton = 1
This does not:
td.Buttons.Add(New TaskDialogButton(2, "Cancel"))
Seems like a bug to me.
-Brent McAnney
”Boost
