Hi !
for testing source by Infrastructure Administrator it is require to start IM, connect to the database and login by project.
is it possible to define start-option and who to define this parameter ?
regards jan
Hallo !
thanks for answer.
current i start with following options:
@augusto.goncalves wrote:
This forum is focused on AutoCAD only... so might be tricky to get a proper suggestion here.
Please check the startup parameters on the .ico of IM, then use the same on Visual Studio debug start parameters. That way you launch debug with the settings you need, if is possible.
regards Jan
