I had a script that eported my models to stl-files.
thisDrawing.SendCommand("STLOUT" +
"g" +
group.Name +
Environment.NewLine +
completeFilename +
Environment.NewLine);
And i used the FACETRES variable to change the model quality.
acApp.SetSystemVariable("FACETRES", 8);
First problem is: Since Acad2021 it does no longer change the variable via script. Other variables like FILEDIA are still working.
Second: I found a better way to export the models. But this example completly ignore the FACETRES value and and export super lowpoly only.
Solid3d sol = (Solid3d)tr.GetObject(myId, OpenMode.ForRead);
sol.StlOut(Path.Combine(targetDirectory, newFileName + ".stl"), true); //ignore facetres settings
It's possible to get a higher quality with that solid3d.stlout command?
Solved by Alexander.Rivilis. Go to Solution.
@stefan.hofer wrote:
...First problem is: Since Acad2021 it does no longer change the variable via script. Other variables like FILEDIA are still working.
Are you sure???
Solid3d sol = (Solid3d)tr.GetObject(myId, OpenMode.ForRead); sol.StlOut(Path.Combine(targetDirectory, newFileName + ".stl"), true); //ignore facetres settings
You can try to P/Invoke AcDb3dSolid::stlOut(const ACHAR* fileName,
Adesk::Boolean asciiFormat, double maxSurfaceDeviation = 0.0 /*use default*/) const;
(available since AutoCAD 2015)
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
-> Are you sure??? yes i am.
double originalfacetres = System.Convert.ToDouble(acApp.GetSystemVariable("FACETRES"));
ed.WriteMessage("FACETRES original value: " + originalfacetres.ToString() + "\n"); //result is 1
double newfacetres = System.Convert.ToDouble(acApp.GetSystemVariable("FACETRES"));
ed.WriteMessage("FACETRES new value: " + newfacetres.ToString() + "\n"); //result is (still) 1
-> AcDb3dSolid
that's objectARX isn't it?
if this is the only way to do this i just give up at this point and live with this result.
Well i found a solution for the FACETRES problem
//Does not work
Autodesk.AutoCAD.ApplicationServices.Core.Application.SetSystemVariable("FACETRES", 8);
//This one work...
AcadDocument myDrawing = (AcadDocument)Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument.GetAcadDocument();
myDrawing.SetVariable("FACETRES", 8);
okay this is a bit embarrassing but my first post was not entirely correct...
Solid3d.StlOut does not ignore the FACETRES value. I had a different problem.
The FACETRES variable is per drawing and not global.
(I create a new drawing for the export and had to change the variable in this new document and everything looks good now)
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(SetFacetRes.MyCommands))]
namespace SetFacetRes
public class MyCommands
[CommandMethod("SetFacetRes")]
public void MyCommand()
Document doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
double fasetRes = (double) Application.GetSystemVariable("FACETRES");
ed.WriteMessage("\nFacetRes={0}", fasetRes);
fasetRes = (double)Application.GetSystemVariable("FACETRES");
What wrong? AutoCAD 2021.1.1
Other way for setting FACETRES is using Database.Facetres property.
-> Other way for setting FACETRES is using Database.Facetres property.
don't forget the DocumentLock this way 🙂
