I know some members are stuck with the 'Slice' API. I will share my experience.
My math is to slice a 3D cube with a plane (made of 3 points) and return a 3D cube that remains. Also, there is a Point3D on the same side as the Output-Solid.
If you have a better solution, Don't hesitate to leave a comment.
It's a pleasure to participate in the discussion in this forum.
Solid3d getSolid(Transaction trans, Solid3d solid, Point3d pt1, Point3d pt2, Point3d pt3, Point3d pointDirect)
Autodesk.AutoCAD.Geometry.Plane slicingPlane = new Autodesk.AutoCAD.Geometry.Plane(pt1, pt2, pt3);
double dotProduct = slicingPlane.Normal.DotProduct(pointDirect - slicingPlane.PointOnPlane);
Solid3d OutputSolid1 = null;
// Determine the side based on the dot product
if (dotProduct > 0)
solid.Slice(slicingPlane, false);
OutputSolid1 = solid;
else if (dotProduct < 0)
OutputSolid1 = solid.Slice(slicingPlane, true);
slicingPlane.Dispose();
return OutputSolid1;
return OutputSolid; // solid3D;
