Hi;
I have a dll file (vb.net) is working in the station with CAD2010 and trying to netload the same dll from another station with CAd 2007 and get this error:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Security.SecurityException: Request for the permission of type 'System.Security.Permissions.SecurityPermission, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' failed.
at System.Security.CodeAccessSecurityEngine.Check(Object demand, StackCrawlMark& stackMark, Boolean isPermSet)
at System.Security.CodeAccessPermission.Demand()
at System.Drawing.Icon.FromHandle(IntPtr handle)
at Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(IWin32Window owner, Form formToShow, Boolean persistSizeAndPosition)
at Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(Form formToShow)
at SDMT.vbstudentClass.TB()
The action that failed was:
Demand
The type of the first permission that failed was:
The first permission that failed was:
version="1"
Flags="UnmanagedCode"/>
The demand was for:
version="1"
The granted set of the failing assembly was:
version="1">
version="1"
Read="USERNAME"/>
version="1"
Unrestricted="true"/>
version="1"
Read="G:\New_NSP\CUSTOM\SDMT\SDMT\obj\Release\"
PathDiscovery="G:\New_NSP\CUSTOM\SDMT\SDMT\obj\Release\"/>
version="1"
Allowed="AssemblyIsolationByUser"
UserQuota="9223372036854775807"
Expiry="9223372036854775807"
Permanent="True"/>
version="1"
Flags="ReflectionEmit"/>
version="1"
Flags="Assertion, Execution, BindingRedirects"/>
version="1"
version="1"
Url="file:///G:/New_NSP/CUSTOM/SDMT/SDMT/obj/Release/SDMT.dll"/>
version="1"
Zone="Intranet"/>
version="1"
version="1"
Level="DefaultPrinting"/>
The assembly or AppDomain that failed was:
SDMT, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
The method that caused the failure was:
Void TB()
The Zone of the assembly that failed was:
Intranet
The Url of the assembly that failed was:
--- End of inner exception stack trace ---
at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at AcMgCommandClass.InvokeWorker(AcMgCommandClass* , MethodInfo mi, Object commandObject, Boolean bLispFunction)
at AcMgPerDocumentCommandClass.Invoke(AcMgPerDocumentCommandClass* , gcroot<:REFLECTION::METHODINFO>* mi, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.TargetInvocationSEHExceptionFilter.InvokeWorker()
at Autodesk.AutoCAD.Runtime.ExceptionFilter.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.832 (QFE.050727-8300)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
Assembly Version: 17.0.209.0
Win32 Version: 17.0.209.0
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/AcdbMgd.DLL
msvcm80
Assembly Version: 8.0.50727.163
Win32 Version: 8.00.50727.163
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.163_x-ww_681e29fb/msvcm80.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Windows.Forms
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
acmgd
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/acmgd.DLL
AcDxUi
Assembly Version: 17.0.54.0
Win32 Version: 17.0.54.0
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/AcDxUi.DLL
AcDx
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/AcDx.DLL
AcDxUi.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/en-US/AcDxUi.resources.DLL
AcMgdShared
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/AcMgdShared.DLL
AcLayer
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/en-US/AcLayer.resources.DLL
SDMT
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///G:/New_NSP/CUSTOM/SDMT/SDMT/obj/Release/SDMT.dll
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
