.NET
Selecting an enclosed area, a la hatch
5 REPLIES 5
870 Views, 5 Replies
Is it possible to prompt selection for an empty area, a la vanilla hatch command? I've written a piece of code where I aimed to select an object, then fill it with hatch. This would've worked had I a single object, but my enclosed space is surrounded by more than a single object or even types of objects.
Hence, I'm in need of a Prompt to select the empty enclosed space instead. Is this possible, or has anyone experience with this kind of thing? My code blow, which was to prompt for an object selection.
public static void HatchArea()
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            Database acCurDb = acDoc.Database;
            Editor docEd = acDoc.Editor;
            PromptKeywordOptions promptKeyOpts = new PromptKeywordOptions("");
            promptKeyOpts.AllowArbitraryInput = false;
            promptKeyOpts.Keywords.Add("Area");
            promptKeyOpts.Keywords.Add("Boundary");
            PromptResult hatchSelRes = docEd.GetKeywords(promptKeyOpts);
            using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                BlockTable acBt;
                acBt = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable;
                BlockTableRecord acBtr;
                acBtr = acTrans.GetObject(acBt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                using (Hatch acHatch = new Hatch())
                    if (hatchSelRes.StringResult == "Area")
                        Point3dCollection p3Coll = new Point3dCollection();
                        PromptEntityOptions promptEntity = new PromptEntityOptions("");
                        PromptEntityResult entityRes = docEd.GetEntity(promptEntity);
                        if (entityRes.ObjectId != null)
                            ObjectId oid = new ObjectId();
                            oid = entityRes.ObjectId;
                            ObjectIdCollection oidCol = new ObjectIdCollection();
                            oidCol.Add(oid);
                            try
                                acBtr.AppendEntity(acHatch);
                                acTrans.AddNewlyCreatedDBObject(acHatch, true);
                                acHatch.AppendLoop(HatchLoopTypes.External, oidCol);
                            catch (SystemException ex)
                                docEd.WriteMessage("Select an enclosed object.");
5 REPLIES 5
Alexander.Rivilis
Create Hatch Objects using Trace Boundaries using .NET
Identifying the boundary through API
Facebook | Twitter | LinkedIn
Expert Elite Member
stefan.hofer
I can not test it now, but it does not work if you select multiple items?
    TypedValue[] acTypValAr = new TypedValue[9];
    acTypValAr.SetValue(new TypedValue((int)DxfCode.Operator, "<or"), 0);
    acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "POLYLINE"), 1);
    acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "LWPOLYLINE"), 2);
    acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "POLYLINE2D"), 3);
    acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "POLYLINE3D"), 4);
    acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "SPLINE"), 5);
    acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "LINE"), 6);
    acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "ARC"), 7);
    acTypValAr.SetValue(new TypedValue((int)DxfCode.Operator, "or>"), 8);
    SelectionFilter acSelFtr = new SelectionFilter(acTypValAr);
    PromptSelectionResult pSelRes;
    PromptSelectionOptions pSelOpts = new PromptSelectionOptions();
    pSelOpts.MessageForAdding = "\nSelect Lines, Polylines, Arcs or Splines: ";
    pSelRes = ed.GetSelection(pSelOpts, acSelFtr);
    if (pSelRes.Status == PromptStatus.OK)
        //your code
_gile
in reply to: stefan.hofer
The POLYLINE2D and POLYLINE3D are not valid DXF entity types (both are types of POLYLINE)
You can build your selection filter in a much more concise way:
TypedValue[] acTypValAr = new TypedValue[1];
acTypValAr.SetValue(new TypedValue(0, "ARC,LINE,LWPOLYLINE,POLYLINE,SPLINE"), 0);
Or simply:
var filter = new SelectionFilter(new[] { new TypedValue(0, "ARC,LINE,LWPOLYLINE,POLYLINE,SPLINE") });
Have a look at the PICKADD system variable
Gilles Chanteau
GileCAD
GitHub
in reply to: Alexander.Rivilis
Well, I'm not the most VB literate, but I've tried to implement it to my best.
                        PromptPointOptions ptOptions = new PromptPointOptions("Select point ");
                        ptOptions.AllowNone = false;
                        PromptPointResult ptResult = docEd.GetPoint(ptOptions);
                        if (ptResult.Status != PromptStatus.OK)
                            return;
                        DBObjectCollection collection = docEd.TraceBoundary(ptResult.Value, true);
                        using (Autodesk.AutoCAD.DatabaseServices.Polyline acPoly = new Autodesk.AutoCAD.DatabaseServices.Polyline())
                            foreach (Object obj in collection)
                                Polyline poly = obj as Polyline;
                                //Autodesk.AutoCAD.DatabaseServices.Entity ent = obj as Autodesk.AutoCAD.DatabaseServices.Entity;
                                if (poly != null)
                                    oid = acBtr.AppendEntity(poly);
                                    oidCol.Add(oid);
                        try
                        catch (Autodesk.AutoCAD.Runtime.Exception ex)
                            Console.WriteLine(ex.Message);
                            return;
It collects some oid's for sure, however I receive Invalid Input exception (at Catch).
As for other inquiries: Yes, I'm sorry I haven't made it clear at first. I could work around this by making the user select multiple items, but that's not my goal. I am trying to make it function similarly to the vanilla hatch command, and am willing to do my other code on the side. If desired, much more easily, hatch creation could be separated from the code itself. I'm just trying to make it a little easier to use.
However, I appreciate the help. I'll look into advice related to see filters. I'm sure I could make use of it somewhere else. Thanks a lot.
I will pass you the code today and explain.
AutoCAD Inside the Factory
