Hi. I have a folowwing problem:
I have a lot of polylines. Some polylines are in one point and I want to select these then delete selected objects.
Example point:
Dim c As Double = 359.1275 Dim point As New Point2d(Val(c), Val(c))
How I would like to select these polyline:
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database Using acLckDoc As DocumentLock = acDoc.LockDocument Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() Dim acSSPrompt As PromptSelectionResult = acDoc.Editor.GetSelection(""Select all In point"") If acSSPrompt.Status = PromptStatus.OK Then Dim acSSet As SelectionSet = acSSPrompt.Value For Each acSSObj As SelectedObject In acSSet If Not IsDBNull(acSSObj) Then Dim acEnt As Entity = acTrans.GetObject(acSSObj.ObjectId, OpenMode.ForWrite) If Not IsDBNull(acEnt) Then acEnt.Erase() End If End If Next acTrans.Commit() End If End Using End Using
but in the "" "" i wrote what i want to select but i don't know how to do it.
Then I would like to choose everything that has not been erase and join it
Solved by _gile. Go to Solution.
If you want to select the polylines crossing a previouly known point without user interaction, you can use the Editor.SelectCrossingWindow passing it the point twice (or two very closed points).
[CommandMethod("TEST1")] public static void Test1() { var ed = AcAp.DocumentManager.MdiActiveDocument.Editor; // selection filter to select only Polyline var filter = new SelectionFilter(new[] { new TypedValue(0, "LWPOLYLINE") }); var point = new Point3d(359.1275, 359.1275, 0.0); var result = ed.SelectCrossingWindow(point, point, filter); // highlight the result if (result.Status == PromptStatus.OK) ed.SetImpliedSelection(result.Value); }
If you want the user to pick a point and select all polylines within the cusor aperture, you can set some PromptSelectionOptions (this also requires to deactivate the selection cycling)
[CommandMethod("TEST2")] public static void Test2() { var ed = AcAp.DocumentManager.MdiActiveDocument.Editor; // selection filter to select only Polyline var filter = new SelectionFilter(new[] { new TypedValue(0, "LWPOLYLINE") }); ; // selection options to select everything in aperture by single pick var options = new PromptSelectionOptions(); options.MessageForAdding = "\nSelect Polylines by point: "; options.SelectEverythingInAperture = true; options.SingleOnly = true; // get the current SELECTIONCYCLING and deactivate it var selectionCycling = Application.GetSystemVariable("SELECTIONCYCLING"); Application.SetSystemVariable("SELECTIONCYCLING", 0); try { // prompt the user for selection var result = ed.GetSelection(options, filter); // highlight the result if (result.Status == PromptStatus.OK) ed.SetImpliedSelection(result.Value); } // restore the previous value of SELECTIONCYCLING finally { Application.SetSystemVariable("SELECTIONCYCLING", selectionCycling); } }
Another way without user interaction could be get all entities ObjectId in current space, filter polylines and check for the distance between the search point and the closest point on polyline to the searche point.
[CommandMethod("Test3")] public static void Test3() { var doc = Application.DocumentManager.MdiActiveDocument; var db = doc.Database; var ed = doc.Editor; var point = new Point3d(359.1275, 359.1275, 0.0); var ids = new ObjectIdCollection(); using (var tr = new OpenCloseTransaction()) { var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite); foreach (ObjectId id in curSpace) { if (id.ObjectClass.DxfName == "LWPOLYLINE") { var pl = (Polyline)tr.GetObject(id, OpenMode.ForRead); if (pl.GetClosestPointTo(point, false).DistanceTo(point) < Tolerance.Global.EqualPoint) { ids.Add(id); } } } var array = new ObjectId[ids.Count]; ids.CopyTo(array, 0); ed.SetImpliedSelection(array); tr.Commit(); } }
This can be written in a more declarative way by using Linq with lambda functions
[CommandMethod("TEST4")] public static void Test4() { var doc = Application.DocumentManager.MdiActiveDocument; var db = doc.Database; var ed = doc.Editor; var point = new Point3d(359.1275, 359.1275, 0.0); using (var tr = new OpenCloseTransaction()) { var ids = ((BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)) .Cast<ObjectId>() .Where(id => id.ObjectClass.DxfName == "LWPOLYLINE") .Select(id => (Polyline)tr.GetObject(id, OpenMode.ForRead)) .Where(pl => pl.GetClosestPointTo(point, false).DistanceTo(point) < Tolerance.Global.EqualPoint) .Select(pl => pl.ObjectId) .ToArray(); ed.SetImpliedSelection(ids); tr.Commit(); } }
