Select objects inside block with a polygon with using .net
anhtrung
Message 1 of 10
anhtrung
Hi anybody,
I have a question and who is help me to solve this problem. That is a have a block and it's contain objects, and it's also have a polyline into block. So, i want to get all object inside block with inside polyline. how to create new function or new any idea help to me.
I'm using C.#
Thanks.
Replies (9)
Message 2 of 10
You could use the Editor. GetNestedEntity() method to get the line.
The objectId is the one the line within the block definition.
            using (var tr = db.TransactionManager.StartTransaction())
                PromptNestedEntityResult result;
                while (true)
                    result = ed.GetNestedEntity("\nSelect a line within a block reference: ");
                    // user cancelled
                    if (result.Status != PromptStatus.OK)
                        return;
                    // check if the selected object is a line
                    if (result.ObjectId.ObjectClass.DxfName == "LINE")
                        // check if the line is nested
                        if (result.GetContainers().Length == 0)
                            ed.WriteMessage("\nThe selected line is not nested in a block reference.");
                        else
                            break;
                    else
                        ed.WriteMessage("\nThe selected entity is not a line.");
                // open the line of the block defintion
                var line = (Line)tr.GetObject(result.ObjectId, OpenMode.ForRead);
                // compute the transformation matrix from the containers
                var xform = result.GetContainers()
                    .Select(id => (BlockReference)tr.GetObject(id, OpenMode.ForRead))
                    .Select(br => br.BlockTransform)
                    .Aggregate((m1, m2) => m2 * m1);
                // transform the line start and ensd points
                var startPoint = line.StartPoint.TransformBy(xform);
                var endPoint = line.EndPoint.TransformBy(xform);
                ed.WriteMessage($"\nStart point: {startPoint}\nEnd point: {endPoint}");
                tr.Commit();
Feel free to contact us is need additional assistance. @anhtrung
Message 3 of 10
anhtrung
Thanks for your answer to me.
This is a function only for one object. I mean want to get objects inside polyline and this objects into a block.
Message 4 of 10
_gile
You should describe what you want to achieve with more details because block references (BlockReference) do not contain entities, they're only inserted references to a block definition (BlockTableRecord).
Only the block definition contains the entites.
Gilles Chanteau
GileCAD
GitHub
Message 5 of 10
anhtrung
Thanks for your information.
Like you can see image below. I have a block reference and i want to get objects inside the yellow polyline.
 File attached.
Message 6 of 10
_gile
As I said, these entities do not belong to the block reference which is only a geometric representation of the block definition. So, you have to elaborate what you mean by: "get objects" and about the context inputs.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 10
anhtrung
I mean, i can define get points boundary yellow plolyline, but i want to get objects inside this polyline, and all this objects into block reference.
Message 8 of 10
_gile
Sorry, I'm not able to help you further
It looks like we do not understand each other
Gilles Chanteau
GileCAD
GitHub
Message 9 of 10
GiaBach
Hi Trung,
Not sure I fully understand your request, just make a snippet.
        public static void GetPlinesInside(BlockReference bref)
            List<Polyline> plLst = new List<Polyline>();
            List<Polyline> boundaryLst = new List<Polyline>();
            DBObjectCollection objs = new DBObjectCollection();
            bref.Explode(objs);
            foreach (DBObject obj in objs)
                if (obj is Polyline pl)
                    if (pl.ColorIndex == 2)
                        boundaryLst.Add(pl);
                    else
                        plLst.Add(pl);
            if (boundaryLst.Count == 1)
                Polyline boundary = boundaryLst[0];
                foreach (Polyline pl in plLst)
                    // checking if the pl is inside boundary, refer the solution of Gile:
                    // https://forums.autodesk.com/t5/net/how-to-check-if-a-point2d-is-inside-a-polyline-or-not/m-p/8234741
                    if (isInside(boundary, pl))
                        // do something here
Message 10 of 10
anhtrung
Thanks for your help. That all i need to do that.
