Select object and divide equal part in c#
I want to select object line,circle or anything and divide equal part with my value in c#.
_gile
Have a look at the Autodesk.AutoCAD.DatabaseServices.Curve methods and properties
get the curve length:
double length = someCurve.GetdistanceAtParameter(someCurve.EndParam);
get a point on the curve at 1/5 of total length:
Point3d point = someCurve.GetPointAtDist(length / 5.0);
Gilles Chanteau
GileCAD
GitHub
_gile
You should get some inspiration from this snippet which mimics the DIVIDE command:
        public void DivideCurve()
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            using (var tr = db.TransactionManager.StartTransaction())
                var rejectMessage = "\nCannot divide that object.";
                var entityOptions = new PromptEntityOptions("\nSelect object to divide: ");
                entityOptions.SetRejectMessage(rejectMessage);
                entityOptions.AddAllowedClass(typeof(Curve), false);
                PromptEntityResult entityResult;
                Curve curve;
                while (true)
                    entityResult = ed.GetEntity(entityOptions);
                    if (entityResult.Status != PromptStatus.OK)
                        return;
                    curve = (Curve)tr.GetObject(entityResult.ObjectId, OpenMode.ForRead);
                    if (curve is Xline || curve is Ray)
                        ed.WriteMessage(rejectMessage);
                    else
                        break;
                var intOptions = new PromptIntegerOptions("\nEnter the number of segments: ");
                intOptions.LowerLimit = 2;
                intOptions.UpperLimit = 32767;
                var intResult = ed.GetInteger(intOptions);
                if (intResult.Status != PromptStatus.OK)
                    return;
                var length = curve.GetDistanceAtParameter(curve.EndParam);
                var numSegments = intResult.Value;
                var dist = length / numSegments;
                var btr = (BlockTableRecord)tr.GetObject(curve.OwnerId, OpenMode.ForWrite);
                for (int i = 1; i < numSegments; i++)
                    var point = new DBPoint(curve.GetPointAtDist(i * dist));
                    btr.AppendEntity(point);
                    tr.AddNewlyCreatedDBObject(point, true);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
