Dynamic Block Point Parameter Visibility
GeeHaa
Message 1 of 10
GeeHaa
Hi
I Posted this at the end of a post that had a solution so I don't think anyone looked at. Sorry for posting it again.
http://adndevblog.typepad.com/autocad/2012/05/accessing-visible-entities-in-a-dynamic-block.html
Hi I'm having trouble with the code in the suggested solution above. I translated it to VB.net and I am getting an error EntryPoint "?" not found in acdb19.dll. I'm using acdb19.dll because it couldn't find acdb18.dll any suggestions would be much appreciated.
Public Sub DynablockVisibilityStates()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
                        Dim per As PromptEntityResult = ed.GetEntity(vbLf + "Select Dynamic Block ")
            If per.Status <> PromptStatus.OK Then
                Return
            Using myTrans As Transaction = db.TransactionManager.StartTransaction()
                Dim ent As Entity = myTrans.GetObject(per.ObjectId, OpenMode.ForRead)
                Dim bref As BlockReference = Nothing
                If TypeOf ent Is BlockReference Then
                    bref = ent
                Dim bt As BlockTable = TryCast(myTrans.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                               Dim btr As BlockTableRecord = myTrans.GetObject(bref.DynamicBlockTableRecord, OpenMode.ForRead)
                               If Not btr.IsDynamicBlock Then
                    ed.WriteMessage(vbLf & "Not a dynamic block :(")
                    Return
                If btr.ExtensionDictionary = Nothing Then
                    ed.WriteMessage(vbLf & "No ExtensionDictionary :(")
                    Return
                Dim dict As DBDictionary = TryCast(myTrans.GetObject(btr.ExtensionDictionary, OpenMode.ForRead), DBDictionary)
                If Not dict.Contains("ACAD_ENHANCEDBLOCK") Then
                    ed.WriteMessage(vbLf & "ACAD_ENHANCEDBLOCK Entry not found :(")
                    Return
                Dim graphId As ObjectId = dict.GetAt("ACAD_ENHANCEDBLOCK")
                Dim parameterIds As System.Collections.Generic.List(Of Object) = acdbEntGetObjects(graphId, 360)
                For Each parameterId As Object In parameterIds
                    Dim id As ObjectId = DirectCast(parameterId, ObjectId)
                    If id.ObjectClass.Name = "AcDbBlockVisibilityParameter" Then
                        Dim visibilityParam As System.Collections.Generic.List(Of TypedValue) = acdbEntGetTypedVals(id)
                        Dim enumerator As System.Collections.Generic.List(Of TypedValue).Enumerator = visibilityParam.GetEnumerator()
                        While enumerator.MoveNext()
                            If enumerator.Current.TypeCode = 303 Then
                                Dim group As String = DirectCast(enumerator.Current.Value, String)
                                Dim nbEntitiesInGroup As Integer = CInt(enumerator.Current.Value)
                                ed.WriteMessage((Convert.ToString(vbLf & " . Visibility Group: ") & group) + " Nb Entities in group: " + nbEntitiesInGroup)
                                For i As Integer = 0 To nbEntitiesInGroup - 1
                                    Dim entityId As ObjectId = DirectCast(enumerator.Current.Value, ObjectId)
                                    Dim entity As Entity = TryCast(myTrans.GetObject(entityId, OpenMode.ForRead), Entity)
                                    ed.WriteMessage(vbLf & "    - " + entity.ToString() + " " + entityId.ToString())
                                Next
                        End While
                        Exit For
                Next
                myTrans.Commit()
            End Using
        End Sub
        Public Structure ads_name
            Private a As IntPtr
            Private b As IntPtr
        End Structure
        <Runtime.InteropServices.DllImport("acdb19.dll", CallingConvention:=System.Runtime.InteropServices.​CallingConvention.Cdecl, EntryPoint:="?acdbGetAdsName@@YA?AW4ErrorStatus@Ac​ad@@AAY01JVAcDbObjectId@@@Z")> _
        Public Shared Function acdbGetAdsName(ByRef name As ads_name, objId As ObjectId) As Integer
        End Function
        <Runtime.InteropServices.DllImport("acad.exe", CharSet:=System.Runtime.InteropServices.CharSet.An​si, CallingConvention:=System.Runtime.InteropServices.​CallingConvention.Cdecl, EntryPoint:="acdbEntGet")> _
        Public Shared Function acdbEntGet(ByRef ename As ads_name) As System.IntPtr
        End Function
        Private Function acdbEntGetObjects(id As ObjectId, dxfcode As Short) As System.Collections.Generic.List(Of Object)
            Dim result As New System.Collections.Generic.List(Of Object)()
            Dim name As New ads_name()
            Dim res As Integer = acdbGetAdsName(name, id)
            Dim rb As New ResultBuffer()
            Autodesk.AutoCAD.Runtime.Interop.AttachUnmanagedOb​ject(rb, acdbEntGet(name), True)
            Dim iter As ResultBufferEnumerator = rb.GetEnumerator()
            While iter.MoveNext()
                Dim typedValue As TypedValue = CType(iter.Current, TypedValue)
                If typedValue.TypeCode = dxfcode Then
                    result.Add(typedValue.Value)
            End While
            Return result
        End Function
        Private Function acdbEntGetTypedVals(id As ObjectId) As System.Collections.Generic.List(Of TypedValue)
            Dim result As New System.Collections.Generic.List(Of TypedValue)()
                result.Add(CType(iter.Current, TypedValue))
            End While
            Return result
        End Function
    End Class
Replies (9)
Message 2 of 10
_gile
Try with this EntryPoint:
"?acdbGetAdsName@@YA?AW4ErrorStatus@Acad@@AEAY01_JVAcDbObjectId@@@Z"
Gilles Chanteau
GileCAD
GitHub
Message 3 of 10
GeeHaa
Thanks for the reply. Unfortunately I get the same error.
An exception of type 'System.EntryPointNotFoundException' occurred in CheckVisibilityofPoints.dll but was not handled in user code
Additional information: Unable to find an entry point named '?' in DLL 'acdb19.dll'.
If there is a handler for this exception, the program may be safely continued.
Here is the modified Statement.
       <Runtime.InteropServices.DllImport("acdb19.dll", CallingConvention:=System.Runtime.InteropServices.CallingConvention.Cdecl, CharSet:=System.Runtime.InteropServices.CharSet.Ansi, EntryPoint:="?acdbGetAdsName@@YA?AW4ErrorStatus@Acad@@AEAY01_J​VAcDbObjectId@@@Z")> _
        End Function
It actually crashes whet it hits this statement.       Dim res As Integer = acdbGetAdsName(name, id)
The variable "name" has the values A=0 and B=0
Sorry I didn't see your reply right away.
Thanks again I appreciate the help.
Message 4 of 10
I need to have this answered as well or point me in another direction.
Message 5 of 10
_gile
The EntryPoint isn't the same for 32 bits or 64 bits platform:
  • 32 bits: ?acdbGetAdsName@@YA?AW4ErrorStatus@Acad@@AAY01JVAcDbObjectId@@@Z
  • 64 bits: ?acdbGetAdsName@@YA?AW4ErrorStatus@Acad@@AEAY01_JVAcDbObjectId@@@Z
You can see this topic.
Gilles Chanteau
GileCAD
GitHub
Message 6 of 10
_gile
For R19 and later, you also have to replace "acad.exe" with "accore.dll" to P/Invoke acdbEntGet() method.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 10
GeeHaa
Thanks for the Responses
Thanks to you both. It works now. Unfortunately it doesn't retrieve the Point Parameters in any of the Visibility groups. Its only showing entities. Is there a way to see the point parameters as well?
Message 8 of 10
_gile
What are you trying to achieve?
You can easily access to the dynamic properties and their values and you probably know which entities are visible according to the visibility state.
        [CommandMethod("dynprops")]
        public void GetDynamicProperties()
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var opts = new PromptEntityOptions("\nSelect a block: ");
            opts.SetRejectMessage("Must be a block.");
            opts.AddAllowedClass(typeof(BlockReference), true);
            var res = ed.GetEntity(opts);
            if (res.Status != PromptStatus.OK)
                return;
            using (var tr = db.TransactionManager.StartTransaction())
                var br = (BlockReference)tr.GetObject(res.ObjectId, OpenMode.ForRead);
                if (br.IsDynamicBlock)
                    foreach (DynamicBlockReferenceProperty prop in br.DynamicBlockReferencePropertyCollection)
                        ed.WriteMessage("\n{0} ({1}) = {2}", prop.PropertyName, prop.PropertyTypeCode, prop.Value);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Message 9 of 10
GeeHaa
I have a program that attaches polylines to point parameters on Dynamic blocks right now it connects to all the points on the block whether they are visible or not. I just want to connect to the visible ones.
Message 10 of 10
GeeHaa
These are the typecodes and values for the two PointParameters in a particular Dynamic Block  I'm probably thinking about this all wrong (I don't have much experience with dictionaries) but I have the objectIDs of the Point parameters. Is there a class I could cast them  into that would give me a visibility state? Internal.databaseServices.Block1PointParameter has everything else but a Visibility State. I even checked the XData..There must be a way to do this. When I select this block in different visibility states only the point parameters of that state show(as grips). Otherwise you cant see them.
All the blocks (there are a few hundred of them) have different names for visibility states so I can't tell which parameters go with what states. Since programmatically I can only get entities from the Visibility states.
Thanks Again for all your help
- -1 (140699525757456)
    - 0 BLOCKPOINTPARAMETER
    - 330 (140699525757376)
    - 5 459
    - 100 AcDbEvalExpr
    - 90 5
    - 98 31
    - 99 106
    - 100 AcDbBlockElement
    - 300 Point
    - 98 31
    - 99 106
    - 1071 0
    - 100 AcDbBlockParameter
    - 280 1
    - 281 0
    - 100 AcDbBlock1PtParameter
    - 1010 (1.5,-0.125,0)
    - 93 6
    - 170 1
    - 91 6
    - 301 DisplacementX
    - 171 1
    - 92 6
    - 302 DisplacementY
    - 100 AcDbBlockPointParameter
    - 303 ConnPt01
    - 304 Connection Point 01
    - 1011 (1.6875,-0.125,0)
    - -1 (140699525757552)
    - 5 45F
    - 100 AcDbEvalExpr
    - 90 16
    - 98 31
    - 99 106
    - 300 Point1
    - 98 31
    - 99 106
    - 1071 0
    - 280 1
    - 281 0
    - 1010 (1.5,-0.875,0)
    - 93 17
    - 170 1
    - 91 17
    - 301 DisplacementX
    - 171 1
    - 92 17
    - 302 DisplacementY
    - 303 ConnPt02
    - 304 Connection Point 02
    - 1011 (1.6875,-0.875,0)
