minimum distance between two entities
How can we find minimum distance between the entities (entity can be a polyline, circle, arc, etc).
_gile
If the entities derive from Curve, you can get the corresponding Curve3d object with the Curve.GetGeCurve() method.
The Curve3d type has a Curve3d.GetDistanceTo(Curve3d) method which returns the minimum distance beween the curves.
Gilles Chanteau
GileCAD
GitHub
Sir,
thank u for reply.
 if there are two entities close to each other( closed entity having four sides ), then how can i get minimum distance between them.?
_gile
Here's a testing command using the process I described upper (requires A2013+ for the GetGeCurve() method).
        [CommandMethod("MinDist")]
        public void GetMinimumDistance()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var options = new PromptEntityOptions("\nSelect first object: ");
            options.SetRejectMessage("Must be a curve.");
            options.AddAllowedClass(typeof(Curve), false);
            var result = ed.GetEntity(options);
            if (result.Status != PromptStatus.OK)
                return;
            var id1 = result.ObjectId;
            options.Message = "\nSelect second object: ";
                return;
            var id2 = result.ObjectId;
            using (var tr = db.TransactionManager.StartTransaction())
                var curve1 = (Curve)tr.GetObject(id1, OpenMode.ForRead);
                var curve2 = (Curve)tr.GetObject(id2, OpenMode.ForRead);
                var distance = curve1.GetGeCurve().GetDistanceTo(curve2.GetGeCurve());
                ed.WriteMessage("\nDistance = {0}", distance);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
thanks u very much..
Hello Gilles,
May I know how to use this? I'm very new to programming.
Do you have any screen shots for this?
Thank you very much in advance.
