.NET
Select an Entity Event?
2 REPLIES 2
781 Views, 2 Replies
when i open a dwg file, and the i can use mouse to click one graphical object, like a line, a circle, an arc and so forth. so my question is, what event is raised when i just click an object, and how can i moniter it? Can anyone post some code for me? That would be of great helpful, thanks!
2 REPLIES 2
Ajilal.Vijayan
Like this ?
The below code I copied from here
Preventing AutoCAD objects from being selected
 void OnSelectionAdded(object sender, SelectionAddedEventArgs e)
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            ObjectId[] addedIds = e.AddedObjects.GetObjectIds();
            for (int i = 0; i < addedIds.Length; i++)
                ObjectId oid = addedIds[i];
                ed.WriteMessage("Selected Item : " +(oid.ObjectClass.DxfName));
in reply to: Ajilal.Vijayan
ok, thanks Ajilal, i will look into the Editor's evnets and i can solve it~
”Boost
