.NET
Recreate a Ellipse by changing its normal
4 REPLIES 4
哀家爆
413 Views, 4 Replies
Hello everyone,
I have some trouble recreating a Ellipse. Here's the scene, there is a Ellipse whose normal is (0,0,-1). I want to recreate the Ellipse whose normal is (0,0,1). How should I change the Ellipse's propertites?
        public static EllipticalArc2d AsEllipticalArc2d(this EllipticalArc3d ellipticalArc)
            EllipticalArc2d result = null;
            if (ellipticalArc.Normal.IsEqualTo(Vector3d.ZAxis))
                result = new EllipticalArc2d(ellipticalArc.Center.AsPoint2d(),
                ellipticalArc.MajorAxis.AsVector2d(), ellipticalArc.MinorAxis.AsVector2d(),
                ellipticalArc.MajorRadius, ellipticalArc.MinorRadius, ellipticalArc.StartAngle, ellipticalArc.EndAngle);
            else
            return result;
But the result  appear in other quadrants.
As the upper pic shows, if the normal of Ellipse is (0,0,1),result is right. But if the normal of Ellipse is (0,0,-1),result is wrong.
4 REPLIES 4
R.Gerritsen4967
in reply to: 哀家爆
What happens when you change the Start- and EndAngle when the normal is -1?
So:
                ellipticalArc.MajorRadius, ellipticalArc.MinorRadius, ellipticalArc.EndAngle, ellipticalArc.StartAngle);
_gile
in reply to: 哀家爆
This seems to work.
public static EllipticalArc3d NegateNormal(this EllipticalArc3d source) =>
    new EllipticalArc3d(
        source.Center,
        source.MajorAxis,
        source.MinorAxis.Negate(),
        source.MajorRadius,
        source.MinorRadius,
        2.0 * Math.PI - source.EndAngle,
        2.0 * Math.PI - source.StartAngle);
Gilles Chanteau
GileCAD
GitHub
_gile
in reply to: _gile
Or, to directly replace the selected ellipse:
Extension method:
public static Ellipse NegateNormal(this Ellipse source) =>
    new Ellipse(
        source.Center,
        source.Normal.Negate(),
        source.MajorAxis,
        source.RadiusRatio,
Testing command:
    [CommandMethod("TEST")]
    public static void Test()
        var doc = Application.DocumentManager.MdiActiveDocument;
        var db = doc.Database;
        var ed = doc.Editor;
        var peo = new PromptEntityOptions("\nSelect Ellipse: ");
        peo.SetRejectMessage("\nSelected object is not an ellipse.");
        peo.AddAllowedClass(typeof(Ellipse), true);
        var per = ed.GetEntity(peo);
        if (per.Status != PromptStatus.OK)
            return;
        using (var tr = db.TransactionManager.StartTransaction())
            var source = (Ellipse)tr.GetObject(per.ObjectId, OpenMode.ForWrite);
            var ellipse = source.NegateNormal();
            var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
            curSpace.AppendEntity(ellipse);
            tr.AddNewlyCreatedDBObject(ellipse, true);
            source.SwapIdWith(ellipse.ObjectId, true, true);
            source.Erase();
            tr.Commit();
Gilles Chanteau
GileCAD
GitHub
哀家爆
in reply to: _gile
Thanks for your reply. Your code works very well!
AutoCAD Inside the Factory
