Reading DWG File with VB.NET without opening Autocad Editor
I'm rather new in .Net, though I want to make a Tool that will help me to analyze Used layers in a Folder with a lot of DWG's.
The subject is simple:
(For now)
Open File Dialogue Box, Select a DWG file, Read the DWG file to extract all layers to a text file.
(Later; read all DGW's of a slected Folder, read all the DWG's, export the layers and relative DWG to a TXT file, reading the txt file with another .Net application, entering a layer Keyword, get the DWG from the TXT file, open the DWG in True View.)
Here is my code for reading 1 DWG:
Imports System.IO
Imports Autodesk.AutoCAD
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Public Class Form1
Private Sub SelectFile_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles SelectFile.Click
Dim myStream As Stream = Nothing
Dim openFileDialog1 As New OpenFileDialog()
openFileDialog1.InitialDirectory = "D:\"
openFileDialog1.Filter = "DWG files (*.dwg)|*.dwg" openFileDialog1.FilterIndex = 1
openFileDialog1.RestoreDirectory = True
If openFileDialog1.ShowDialog() = System.Windows.Forms.DialogResult.OK Then
Try
myStream = openFileDialog1.OpenFile()
Finally
End Try
If openFileDialog1.FileName.Length = 0 Then Exit Sub
Dim TextLine As String = Nothing
Dim objReader As New System.IO.StreamReader(myStream)
'Set path to DWGfile:
Dim myfile As String = Nothing
myfile = openFileDialog1.FileName
myfile = myfile.Replace(".dwg", ".txt")
'Delete Txt file if exists
Dim FileToDelete As String
FileToDelete = myfile
If System.IO.File.Exists(FileToDelete) = True Then System.IO.File.Delete(FileToDelete)
Dim objWriter As New System.IO.StreamWriter(myfile)
'Open the DWG File For Reading
Dim myDB As New DatabaseServices.Database
myDB.ReadDwgFile(openFileDialog1.FileName, FileOpenMode.OpenForReadAndAllShare, True)
Dim myBT As DatabaseServices.BlockTable = myDB.BlockTableId.GetObject(OpenMode.ForRead)
Dim myBTR As DatabaseServices.BlockTableRecord = myBT(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForRead)
For Each myObjID As ObjectId In myBTR
Dim myEntity As Entity = myObjID.GetObject(OpenMode.ForRead)
If myEntity.Layer.Length > 2 Then objWriter.Write(myEntity.Layer.Length)
Next
objWriter.Close()
myStream.Close()
MessageBox.Show("Writing succesful!", "Layer list", MessageBoxButtons.OK, MessageBoxIcon.Information)
Me.Close()
End Sub
End Class
Copying this into VS 2008 does not give any Errors
The 2 necessary autocad dll's acdbmgd.dll and acmgd.dll are loaded and not copied.
Still when I want to run this code I receive the error:
Could not load assembly acdbmgd, Version=18.0.0.0, Culture=neutral, PublicKeyToken=null ...
Can anyone solve this problem? Which dll I have to add? Do I have to use other autocad dll ?
Thanx for reading this Subject.
Hope to receive an awnser.
In general there are 3 AutoCAD DLL's to load: AcDbMgd.dll, AcMgd.dll, AcCui.dll
But the versions depend on the AutoCAD version, AutoCAD 2008..2011
Also the version of VisStudio and the framework to compile to depends on the AutoCAD version.
Try to figure out the required combinations with just a simple program displaying a MsgBox.
Hello Frits,
I'm working with VS 2008, Autocad 2010 (Civil or Map) - 32 bit version, Framework 3.5.
I'm gonna try your proposal.
Hopefully this works.
dgorsman
Not sure if your title is fully accurate.  Under most circumstances (like creating a DLL) you *must* run AutoCAD.  To clarify, do you mean doing this task without opening each drawing on screen, or without running the AutoCAD application?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
ehsan_bahrani
(For now)
Imports System.IO
Public Class Form1
Try
Finally
End Try
Next
objWriter.Close()
myStream.Close()
Me.Close()
End Sub
End Class
(For now)
Imports System.IO
Public Class Form1
Try
Finally
End Try
Next
objWriter.Close()
myStream.Close()
Me.Close()
End Sub
End Class
you have to set "Copy Local" to True
after that when using transAction i will get an error! (System.InvalidProgramException: 'Common Language Runtime detected an invalid program.')
any suggestion?
