How to use .Net to cutting double line automatic?
hi,everyone. i have some  trouble in .NET,the drawing blow ,the left   is a double line ,the right has two double line,one is at the end ,the other is at the middle,how can they cut  automatic like this when drawing  these double lines?thanks
do you mean "multiline"...
jvj
yes,multiline
Hallex
You could play with this code
    ''============================cut mline=====================
    <DllImport("acad.exe", BestFitMapping:=True, CallingConvention:=CallingConvention.Cdecl, CharSet:=CharSet.Auto)> _
    Private Shared Function acedCmd(ByVal vlist_in As System.IntPtr) As Integer
    End Function
    <CommandMethod("MCUT")> _
    Public Shared Sub CutMline()
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim doc As Document = acApp.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        Using tr
            Try
                Dim peo As New PromptEntityOptions(vbLf & "Select first mline:")
                peo.SetRejectMessage(vbLf & "Select mline only")
                peo.AddAllowedClass(GetType(Mline), True)
                Dim per As PromptEntityResult = ed.GetEntity(peo)
                If per.Status <> PromptStatus.OK Then
                    Return
                Dim fid As ObjectId = per.ObjectId
                peo.Message = vbLf & "Select second mline:"
                per = ed.GetEntity(peo)
                    Return
                Dim sid As ObjectId = per.ObjectId
                Dim ids As ObjectId() = New ObjectId(1) {}
                ids(0) = fid
                ids(1) = sid
                Dim obj1 As DBObject = tr.GetObject(fid, OpenMode.ForWrite)
                Dim obj2 As DBObject = tr.GetObject(sid, OpenMode.ForWrite)
                'acApp.SetSystemVariable("FILLETRAD", rad)
                acApp.SetSystemVariable("CMDECHO", 0)
                Dim buf As New ResultBuffer()
                buf.Add(New TypedValue(5005, "_-MLEDIT"))
                buf.Add(New TypedValue(5005, "CT")) ''<--change editing option here [CC/OC/MC/CT/OT/MT/CJ/AV/DV/CS/CA/WA]
                buf.Add(New TypedValue(5006, fid))
                buf.Add(New TypedValue(5006, sid))
                buf.Add(New TypedValue(5005, ""))
                acedCmd(buf.UnmanagedObject)
                buf.Dispose()
                acApp.SetSystemVariable("CMDECHO", 1)
                tr.Commit()
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
            End Try
        End Using
    End Sub
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
thanks ,hallex.
i used the code you post,but it'does'nt work like i think.see the below pic.
Hallex
Change editing option jn what you need: CC/OC/MC/CT/OT/MT/CJ/AV/DV/CS/CA/WA
