.NET
699 Views, 2 Replies
Purging
Need a bit of help with purging materials from a drawing. I have managed to purge all items within a named object table like layers and blocks but those in the Named Object dictionary table are confusing me a little.
Do I need to itterate through the named objects dictionarys to get the AEC_MATERIAL_DEFS dictionary then purge the contents from there?
Thanks for any help.
Daniel
2 REPLIES 2
_gile
This will purge all non referenced materials
{code}ObjectIdCollection ids = new ObjectIdCollection();
using (Transaction tr = db.TransactionManager.StartTransaction())
DBDictionary matDict = (DBDictionary)tr.GetObject(db.MaterialDictionaryId, OpenMode.ForRead, false);
foreach (DBDictionaryEntry entry in matDict)
string key = entry.Key;
if ((key != "ByBlock") && (key != "ByLayer") && (key != "Global"))
ids.Add(entry.Value);
db.Purge(ids);
foreach (ObjectId id in ids)
DBObject obj = (DBObject)tr.GetObject(id, OpenMode.ForWrite);
obj.Erase();
tr.Commit();
}{code} Edited by: _gile on Jan 19, 2010 1:28 PM
Gilles Chanteau
GileCAD
GitHub
I see, you can directly access the materialdictionaryID - I thought it would need itterating through each named dictionary to find the materials dictionary.
Thanks Gile.
”Boost
