Publish my plugin into APP Store
Amremad
Message 1 of 9
Amremad
Hello all
what's the best way to publish my plugin into app store ?
Replies (8)
Message 2 of 9
_gile
You can read this:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=20149725
Gilles Chanteau
GileCAD
GitHub
Message 3 of 9
Hi
above link is not working now. can you please send any other reference?
Message 4 of 9
_gile
Message 5 of 9
do you any idea how to make .msi for our .dll files?
Message 6 of 9
_gile
If you provide a .bundle folder to use the Autoloader mechanism (as recommended) the Apps Store team will build the installer (msi) for you.
If you absolutely need to create your own, you can use a Visual Extension as Wix, InstallShield etc. Dy my side i use the Microsoft Visual Studio Installer Projects extension because I used to use it while it was part of Visual Studio (since VS 2012 if I remember well).
Gilles Chanteau
GileCAD
GitHub
Message 7 of 9
thanks Gile..
Message 8 of 9
saifumk8
I had the same question.
Thank you @Anonymous  @_gile @Amremad
Message 9 of 9
CADbloke
If you want to build your own MSI installer, have a look at https://github.com/cyrillef/apps.exchange.packager
Or better still, https://github.com/oleg-shilo/wixsharp but you will have to work out the XML stuff which Cyrille's Python project does for you.
working on all sorts of things including www.tvCAD.tv & www.CADreplace.com
