Probleme With TraceBoundary and Region.createFromCurves
reithinger
reithinger
I have a function with traceBoundary and than i use the Region.CreateFromCurves Method.
This make me an eInvalidInput Error.
This is only in one case (see attach) wenn I Click the left (Blue) Region.
The Problem come from the Line (Red). Autocad can't execute the Region.CreateFromCurves.
I don't know waht I can do to correct this.
Have you any Idea.
I give you my Method (Merge.txt)
With Bricscad I don't have any Error only Autocad
Thanks for your help
Fabrice
lena.talkhina
Hello @reithinger !
I know it's been a long time when you posted, but I would suggest to update information here in your thread if you are still looking for a solution.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
