Print multiple window in model space
BIM_VIET
BIM_VIET
Hi all,
At model space, I would like to print out to pdf the multiple drawing as the photo below, and merge to one file pdf after finish. The points of windows is diagonal blue line.
1. I try follow instruction by Kean : https://www.keanw.com/2007/10/plotting-a-wind.html
But just only made 1 pdf per time. If I put it into loop but error at CreatePublishEngine().or pe.BeginPlot(ppd, null);
2. Any ideal to merge all into 1 pdf after finish.
Ed__Jobe
As @norman.yuan noted in the other thread you replied to, the solution is to use a 3rd party pdf library to combine the sheets into one pdf after they are printed. Otherwise you can just use sheetset manager, but it requires actual sheets to print, not just rectangles in model space. All you would have to do is create a sheet and a single viewport for each plot area.
Ed
How to post your code.
norman.yuan
I agree with @Ed__Jobe : if possible, you should present these contents in ModelSpace in mutiple Layouts, so that any CAD user can easily print them with "Publish" command. No need to re-invent the wheel (for such a regular Acad operation). It is also very easy to use Publish API (which you have already found) to print them, as if it is done manually.
It is certainly doable entirely by code, using either PlotEngine, or Publish API. But in your case (assume all the rectangle area are in the same size), it might be easier to code by:
1. identify the rectangle size (height, width, center) and the quantity of the rectangles
2. create a layer for each rectangle and open a viewport to present the rectangle in proper scale
3. SAVE THE DRAWING (it is required before you can run Publish API code to print these layout
4. Write code to use Publish API to print. You can (and have already) find plenty of code samples of this.
The good outcome of this is that now you have the layouts created to present these rectangles, and they can easily be printed/published later by any CAD user.
Norman Yuan
Drive CAD With Code
maratovich
No problem, use this - Revers
In the program, click "Publish to PDF", a multi-sheet one file will be created.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
