Hi everyone!
I have developed an application which open a dialog window to select multiple drawing files and prompt user to specify the layer name, then iterate through all files one by one and select a rectangle by the user specified layer. And then make its vertices the plot area and then plot to pdf. But it's doing nothing. I don't understand why? Need help.
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.PlottingServices;
using Autodesk.AutoCAD.Runtime;
using System;
using System.IO;
using System.Windows.Forms;
using Application = Autodesk.AutoCAD.ApplicationServices.Core.Application;
namespace PlotMultiDrawingsToPdf
public class Class1 : IExtensionApplication
#region
public void Initialize()
public void Terminate()
#endregion
[CommandMethod("OO")]
public void ProcessFilesSelection()
var doc = Application.DocumentManager.MdiActiveDocument;
var ed = doc.Editor;
var dir = Path.GetDirectoryName(doc.Name);
try
var openFileDialog = new OpenFileDialog()
Multiselect = true,
InitialDirectory = dir,
Filter = "DWG Files (*.dwg) | *.dwg"
}; if (openFileDialog.ShowDialog() == DialogResult.OK)
var layerName = string.Empty;
while (string.IsNullOrEmpty(layerName))
var layResult = ed.GetString("\nEnter the layer name: ");
if (layResult.Status != PromptStatus.OK)
ed.WriteMessage("\nUser canceled input. Exiting...");
return;
layerName = layResult.StringResult.Trim();
if (string.IsNullOrEmpty(layerName))
ed.WriteMessage("\nEmpty layer name. Please enter a valid layer name.");
foreach (var file in openFileDialog.FileNames)
SearchObjectByLayer(file, layerName);
else
ed.WriteMessage("\nNo files selected. Exiting...");
return;
catch (Autodesk.AutoCAD.Runtime.Exception ex)
Console.WriteLine($"{ex.Message}");
static void SearchObjectByLayer(string fileName, string layerName)
try
using (var db = new Database(false, true))
var path = Path.GetFullPath(fileName);
db.ReadDwgFile(fileName, FileShare.ReadWrite, true, "");
using (var tr = db.TransactionManager.StartTransaction())
var bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
var btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead) as BlockTableRecord;
foreach (ObjectId entId in btr)
var ent = tr.GetObject(entId, OpenMode.ForRead) as Entity;
if (ent != null && ent.Layer.Equals(layerName, StringComparison.OrdinalIgnoreCase) && ent is Polyline polyLine && polyLine.NumberOfVertices == 4)
var point1 = polyLine.GetPoint3dAt(0);
var point2 = polyLine.GetPoint3dAt(2);
ProcessPlotToPdf(fileName, point1, point2, Path.Combine(path + "\\PDF"));
tr.Commit();
Console.WriteLine($"Error processing file: {fileName}\n{ex.Message}");
static void ProcessPlotToPdf(string fileName, Point3d point1, Point3d point2, string path)
Document doc = Application.DocumentManager.MdiActiveDocument;
try
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
var layout = (Layout)tr.GetObject(btr.LayoutId, OpenMode.ForRead);
PlotSettings plotSettings = new PlotSettings(layout.ModelType);
plotSettings.CopyFrom(layout);
var plotSettingsValidator = PlotSettingsValidator.Current;
Extents2d plotWindowExtents = new Extents2d(new Point2d(point1.X, point1.Y), new Point2d(point2.X, point2.Y));
plotSettings.ScaleLineweights = true;
plotSettingsValidator.SetPlotWindowArea(plotSettings, plotWindowExtents);
plotSettingsValidator.SetPlotType(plotSettings, Autodesk.AutoCAD.DatabaseServices.PlotType.Window);
plotSettingsValidator.SetUseStandardScale(plotSettings, true);
plotSettingsValidator.SetStdScaleType(plotSettings, StdScaleType.ScaleToFit);
plotSettingsValidator.SetPlotRotation(plotSettings, PlotRotation.Degrees180);
plotSettingsValidator.SetPlotCentered(plotSettings, false);
plotSettingsValidator.SetPlotConfigurationName(plotSettings, "DWG To PDF.pc3", "ISO_full_bleed_A4_(210.00_x_297.00_MM)");
PlotInfo plotInfo = new PlotInfo
Layout = btr.LayoutId,
OverrideSettings = plotSettings
PlotInfoValidator piv = new PlotInfoValidator
MediaMatchingPolicy = MatchingPolicy.MatchEnabled
piv.Validate(plotInfo);
tr.Commit();
using (PlotEngine plotEngine = PlotFactory.CreatePublishEngine())
plotEngine.BeginPlot(null, null);
plotEngine.BeginDocument(plotInfo, doc.Name, null, 1, true, path);
PlotPageInfo pageInfo = new PlotPageInfo();
try
plotEngine.BeginPage(pageInfo, plotInfo, true, null);
Console.WriteLine(ex.ToString());
plotEngine.BeginGenerateGraphics(null);
plotEngine.EndGenerateGraphics(null);
plotEngine.EndPage(null);
plotEngine.EndDocument(null);
plotEngine.EndPlot(null);
Console.WriteLine($"Error plotting file: {fileName}\n{ex.Message}");
