Plot to PDF not working.
luckyboy82292
luckyboy82292
Hi everyone!
I have developed an application which open a dialog window to select multiple drawing files and prompt user to specify the layer name, then iterate through all files one by one and select a rectangle by the user specified layer. And then make its vertices the plot area and then plot to pdf. But it's doing nothing. I don't understand why? Need help.
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.PlottingServices;
using Autodesk.AutoCAD.Runtime;
using System;
using System.IO;
using System.Windows.Forms;
using Application = Autodesk.AutoCAD.ApplicationServices.Core.Application;
namespace PlotMultiDrawingsToPdf
    public class Class1 : IExtensionApplication
        #region
        public void Initialize()
        public void Terminate()
        #endregion
        [CommandMethod("OO")]
        public void ProcessFilesSelection()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var ed = doc.Editor;
            var dir = Path.GetDirectoryName(doc.Name);
            try
                var openFileDialog = new OpenFileDialog()
                    Multiselect = true,
                    InitialDirectory = dir,
                    Filter = "DWG Files (*.dwg) | *.dwg"
                };                if (openFileDialog.ShowDialog() == DialogResult.OK)
                    var layerName = string.Empty;
                    while (string.IsNullOrEmpty(layerName))
                        var layResult = ed.GetString("\nEnter the layer name: ");
                        if (layResult.Status != PromptStatus.OK)
                            ed.WriteMessage("\nUser canceled input. Exiting...");
                            return;
                        layerName = layResult.StringResult.Trim();
                        if (string.IsNullOrEmpty(layerName))
                            ed.WriteMessage("\nEmpty layer name. Please enter a valid layer name.");
                    foreach (var file in openFileDialog.FileNames)
                        SearchObjectByLayer(file, layerName);
                else
                    ed.WriteMessage("\nNo files selected. Exiting...");
                    return;
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                Console.WriteLine($"{ex.Message}");
        static void SearchObjectByLayer(string fileName, string layerName)
            try
                using (var db = new Database(false, true))
                    var path = Path.GetFullPath(fileName);
                    db.ReadDwgFile(fileName, FileShare.ReadWrite, true, "");
                    using (var tr = db.TransactionManager.StartTransaction())
                        var bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                        var btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead) as BlockTableRecord;
                        foreach (ObjectId entId in btr)
                            var ent = tr.GetObject(entId, OpenMode.ForRead) as Entity;
                            if (ent != null && ent.Layer.Equals(layerName, StringComparison.OrdinalIgnoreCase) && ent is Polyline polyLine && polyLine.NumberOfVertices == 4)
                                var point1 = polyLine.GetPoint3dAt(0);
                                var point2 = polyLine.GetPoint3dAt(2);
                                ProcessPlotToPdf(fileName, point1, point2, Path.Combine(path + "\\PDF"));
                        tr.Commit();
                Console.WriteLine($"Error processing file: {fileName}\n{ex.Message}");
        static void ProcessPlotToPdf(string fileName,  Point3d point1, Point3d point2, string path)
            Document doc = Application.DocumentManager.MdiActiveDocument;
            try
                        BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
                        var layout = (Layout)tr.GetObject(btr.LayoutId, OpenMode.ForRead);
                        PlotSettings plotSettings = new PlotSettings(layout.ModelType);
                        plotSettings.CopyFrom(layout);
                        var plotSettingsValidator = PlotSettingsValidator.Current;
                        Extents2d plotWindowExtents = new Extents2d(new Point2d(point1.X, point1.Y), new Point2d(point2.X, point2.Y));
                        plotSettings.ScaleLineweights = true;
                        plotSettingsValidator.SetPlotWindowArea(plotSettings, plotWindowExtents);
                        plotSettingsValidator.SetPlotType(plotSettings, Autodesk.AutoCAD.DatabaseServices.PlotType.Window);
                        plotSettingsValidator.SetUseStandardScale(plotSettings, true);
                        plotSettingsValidator.SetStdScaleType(plotSettings, StdScaleType.ScaleToFit);
                        plotSettingsValidator.SetPlotRotation(plotSettings, PlotRotation.Degrees180);
                        plotSettingsValidator.SetPlotCentered(plotSettings, false);
                        plotSettingsValidator.SetPlotConfigurationName(plotSettings, "DWG To PDF.pc3", "ISO_full_bleed_A4_(210.00_x_297.00_MM)");
                        PlotInfo plotInfo = new PlotInfo
                            Layout = btr.LayoutId,
                            OverrideSettings = plotSettings
                        PlotInfoValidator piv = new PlotInfoValidator
                            MediaMatchingPolicy = MatchingPolicy.MatchEnabled
                        piv.Validate(plotInfo);
                        tr.Commit();
                        using (PlotEngine plotEngine = PlotFactory.CreatePublishEngine())
                            plotEngine.BeginPlot(null, null);
                            plotEngine.BeginDocument(plotInfo, doc.Name, null, 1, true, path);
                            PlotPageInfo pageInfo = new PlotPageInfo();
                            try
                                plotEngine.BeginPage(pageInfo, plotInfo, true, null);
                                Console.WriteLine(ex.ToString());
                            plotEngine.BeginGenerateGraphics(null);
                            plotEngine.EndGenerateGraphics(null);
                            plotEngine.EndPage(null);
                            plotEngine.EndDocument(null);
                            plotEngine.EndPlot(null);
                Console.WriteLine($"Error plotting file: {fileName}\n{ex.Message}");
_gile
You should define a method which takes a Database as argument (and possibly a layer Name) to be able to test and debug this method in the current drawing by calling it from a CommandMethod.
And when you're satisfied with the result, you can pass this method to a 'BatchProcess' one (see this example).
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
luckyboy82292
I have debugged the code. And got this: "eRepeatedDwgReadError plotting file"
luckyboy82292
I have changed the code look like this, but the error still exist. It says "eLayoutNotCurrent". But if we look at code there is no issue. It should work without error but not. Could you please take a look and spot the error?
Here is code:
using System;
using System.IO;
        #region
        #endregion
                Multiselect = true,
                        return;
            else
                return;
            var ed = Application.DocumentManager.MdiActiveDocument.Editor;
            var path = Path.GetDirectoryName(fileName);
            try
                    db.ReadDwgFile(fileName, FileShare.ReadWrite, false, "");
                                ProcessPlotToPdf(tr, btr, point1, point2, Path.Combine(path + "\\PDF"));
                        tr.Commit();
                ed.WriteMessage($"\nError1: {ex.Message}");
        static void ProcessPlotToPdf(Transaction tr, BlockTableRecord btr, Point3d point1, Point3d point2, string path)
            try
                PlotInfo plotInfo = new PlotInfo()
                plotInfo.Layout = btr.LayoutId;
                var plotSettings = new PlotSettings(layout.ModelType);
                var plotWindowExtents = new Extents2d(new Point2d(point1.X, point1.Y), new Point2d(point2.X, point2.Y));
                plotSettingsValidator.SetPlotRotation(plotSettings, PlotRotation.Degrees000);
                plotInfo.OverrideSettings = plotSettings;
                var piv = new PlotInfoValidator
                PlotEngine pe = PlotFactory.CreatePublishEngine();
                using (pe)
                    PlotProgressDialog ppd = new PlotProgressDialog(false, 1, true);
                    using (ppd)
                        ppd.set_PlotMsgString(PlotMessageIndex.DialogTitle, "Custom Plot Progress");
                        ppd.set_PlotMsgString(PlotMessageIndex.CancelJobButtonMessage, "Cancel Job");
                        ppd.set_PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage, "Cancel Sheet");
                        ppd.set_PlotMsgString(PlotMessageIndex.SheetSetProgressCaption, "Sheet Set Progress");
                        ppd.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption, "Sheet Progress");
                        ppd.LowerPlotProgressRange = 0;
                        ppd.UpperPlotProgressRange = 100;
                        ppd.PlotProgressPos = 0;
                        ppd.OnBeginPlot();
                        ppd.IsVisible = true;
                        pe.BeginPlot(ppd, null);
                        pe.BeginDocument(plotInfo, doc.Name, null, 1, true, path);
                        ppd.OnBeginSheet();
                        ppd.LowerSheetProgressRange = 0;
                        ppd.UpperSheetProgressRange = 100;
                        ppd.SheetProgressPos = 0;
                        PlotPageInfo ppi = new PlotPageInfo();
                        pe.BeginPage(ppi, plotInfo, true, null);
                        pe.BeginGenerateGraphics(null);
                        pe.EndGenerateGraphics(null);
                        pe.EndPage(null);
                        ppd.SheetProgressPos = 100;
                        ppd.OnEndSheet();
                        pe.EndDocument(null);
                        ppd.PlotProgressPos = 100;
                        ppd.OnEndPlot();
                        pe.EndPlot(null);
                ed.WriteMessage($"\nError3: {ex.Message}");
luckyboy82292
Please help me with this. Thank you!
_gile
You got "eLayoutNotCurrent" because the 'side database' is not the working database.
You have to temporarily set this 'side database' as working database while plotting and restore the previous working database before disposing it. To do it, you can use the WorkingDatabase class from "ActivistInvestor" (AKA Tony Tanzillo).
That said, I think using the 'side database' way to do batch plotting is not a so good idea. You could define a Command to plot the current drawing and use the accoreconsole for the batch processing.
Gilles Chanteau
GileCAD
GitHub
luckyboy82292
Thank you Sir! You saved my time. It's working fine.
