I have the below function to update the joint Slope tolerances.
Updating the values in the ConnectionManager.config (from PnP3dConnectionManager.dll) instance appears to change the values.
public static void ChangeAllJointSlopeTolerances(double tolerance)
var ed = Application.DocumentManager.MdiActiveDocument.Editor;
var project = Autodesk.ProcessPower.PlantInstance.PlantApplication.CurrentProject;
if (PnPProjectUtils.GetActiveDocumentType() != "Piping") return;
var pipingProject = project.ProjectParts["Piping"] as PipingProject;
var connectionManager = pipingProject.ConnectionManager as ConnectionManager;
var jointsConfiguration = connectionManager.Config.JointsConfiguration;
foreach (var joint in jointsConfiguration.Joints)
joint.SlopeTolerance = tolerance;
But then saving the project doesn't update the config file that stores these values : in Plant Project folder DefaultConnectorsConfig.xml
I'm probably missing some fundamental information about how saving and updating internal databases works. Any pointers to documentation would be appreciated.
