.NET
PaletteSet docking via C# not working in AutoCAD 2016
6 REPLIES 6
pfk
2022 Views, 6 Replies
Hi
I open a new window docked to the AutoCAD 2015 UI as follows (in C# .NET):
                m_SetupFormPalette = new PaletteSet("MyPalette");
                m_SetupFormPalette.Size = new Size(370, Math.Max(350, m_SetupFormPalette.Size.Height));
                m_SetupFormPalette.DockEnabled = (DockSides)((int)DockSides.Left + (int)DockSides.Right);
                m_SetupFormPalette.Dock = Autodesk.AutoCAD.Windows.DockSides.Left;
                m_SetupFormPalette.Add("MyForm", m_SetupForm);
                m_SetupFormPalette.KeepFocus = false;
                m_SetupFormPalette.Visible = true;
This code does NOT work for AutoCAD 2016.  The window always opens UNDOCKED.  Is this a bug in AutoCAD 2016, or I am setting up the docking settings incorrectly?
Paul
6 REPLIES 6
moogalm
in reply to: pfk
Thanks for reporting this behavior to us, I've contacted my Engineering team for analysis.
in reply to: moogalm
I'm experiencing the same problem currently. Are there already known workarounds?
Best regards,
Matthias
moogalm
Sorry the behavior is recently reported to us, we don't have any workarounds at moment.
found out it works for me if I make the PaletteSet visible before im setting the Dock-Property. The question remains why this behaviour has changed between AC2015 and AC2016.
pfk
Thank you - that provided a workaround for resolved my immediate issue.
Paul
in reply to: pfk
Hi folks!
Problem still exists for AutoCAD 2017 SP1.
Luckily the workaround, too.
Technology Administrators
