.NET
Noun-Verb Object Erase
2 REPLIES 2
SRSDS
433 Views, 2 Replies
SRSDS
I need to review entities before erasing them.
I was assessing entities in the CommandWillStart and finding associated objects
In CommandWillStart I collected any associated objects via their Xdata.
In the CommandWillEnd Event I dealt with their associated objects.
Then I realized there was a Noun-Verb Object Erase. (Where the user entered the Erase command then selected objects.)
I could use an Erase ObjectOverrule but that would need to open and close a Transaction for each entity to review it's Xdata. Would this slow my app down? Or is there more sensible alternative?
2 REPLIES 2
jabowabo
in reply to: SRSDS
jabowabo
Maybe watch for the Object.Erased event and unerase as necessary.
SRSDS
in reply to: jabowabo
SRSDS
I think I understand the problems I've been having
A)
I don't need a transaction to read xdata in db.ObjectErased
Dim myXdata As Array = e.DBObject.GetXDataForApplication(AppName).AsArray
B)
Even if I did I was having problems when I was using .StartTransaction when I should have been using .StartOpenCloseTransaction
Thank you. That pointed me in the direction I needed to recap my memory.
A)
B)
AutoCAD Inside the Factory
