Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
.NET
No of entities in Modelspace
6 REPLIES 6
GeeHaa
1805 Views, 6 Replies
Hi
Is there a quick way to get the Number of entities in modelspace without doing a for each and counting them. I need to show a progress bar and I don't want to take time to step through them twice.
Thanks in Advance
6 REPLIES 6
Keith.Brown
in reply to: GeeHaa
The Database.Handseed will give you the next available handle number.  Just convert that to an integer.  It is extremely down and dirty so if you had a large amount of items in your drawing and then they were deleted then I am not sure how it handles it.
BKSpurgeon
in reply to: GeeHaa
You could try
Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            PromptSelectionResult psr = ed.SelectAll();
            int NumberOfEntities = psr.Value.Count;
although i'm not sure that it internally iterates over all of them -- I don't think it does.
_gile
in reply to: GeeHaa
AFAIK there's no other way than iterating the model space.
The Database.Handseed will be much greater than the number of entities in model space: every non graphical object (symbol tables, symbol table records, dictionaries, xrecords, etc. also do have a handle.
Editor.SelectAll (used with a filter to get only model space entities) does iterate the modelspace (how could it be otherwise?) and is, from the tests I did slower than iterating the model space to fill an ObjectIdCollection.
Testing commands:
        [CommandMethod("CountBySelection")]
        public void CountBySelection()
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            var sw = new Stopwatch();
            sw.Start();
            ObjectId[] ids = null;
            for (int i = 0; i < 10; i++)
                ids = ed.SelectAll(new SelectionFilter(new[] { new TypedValue(410, "Model") })).Value.GetObjectIds();
            sw.Stop();
            ed.WriteMessage($"\nFound {ids.Length} entities in {sw.ElapsedMilliseconds / 10} milliseconds");
        [CommandMethod("CountByIteration")]
        public void CountByIteration()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            sw.Start();
            ObjectIdCollection ids = null;
                ids = new ObjectIdCollection();
                using (var tr = db.TransactionManager.StartTransaction())
                    var ms = (BlockTableRecord)tr.GetObject(
                        SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead);
                    foreach (ObjectId id in ms)
                        ids.Add(id);
                    tr.Commit();
            sw.Stop();
            ed.WriteMessage($"\nFound {ids.Count} entities in {sw.ElapsedMilliseconds/ 10} milliseconds");
Results:
Commande: COUNTBYSELECTION
Found 106375 entities in 198 milliseconds
Commande: COUNTBYITERATION
Found 106375 entities in 31 milliseconds
Gilles Chanteau
GileCAD
GitHub
BKSpurgeon
in reply to: _gile
Hi Thank you Gilles for this enlgihtening post - did not realise that it was so significantly slower
_gile
in reply to: BKSpurgeon
Specifically in this case where we just get the ObjectId.
Iterating would be slown down by filtering ObjectId by type (ObjectId.ObjectClass) or more if the entities need to be opened (to check layer for example). In this last case, I think a filtered selection can be a little faster (but not sure).
Gilles Chanteau
GileCAD
GitHub
GeeHaa
in reply to: _gile
Thanks Very much.
Iterating through is a lot quicker than I thought!
AutoCAD Inside the Factory
