Hi! I am developing a C# application for our company since about 6 months. I load my builded dll into AutoCad Map with the netload command. In AutoCAD 2022 everything worked fine, so my public methods were accessible with typing in ACAD editor.
Now I installed AutoCAD Map 2022 and the same dll doesn't work anymore. I load it as usual with the netload command but my methods aren't accessible. Also my initialize function output isn't be written in the editor.
Has anything been changed between the 2020 and the 2022 version? I don't find any development changelog or something like that. I've been searching now for two days.
The following command should be accessible, doesn't it?
[CommandMethod("DebugGetHaltungStartEndWidth", CommandFlags.Session)]
public void GetHaltungStartEndWidth()
Entity entityObj = helpers.GetHaltungUI("Haltung");
if (entityObj == null)
return;
Polyline pLine = entityObj as Polyline;
for (int i = 0; i < pLine.NumberOfVertices; i++)
helpers.EditorWriteLine("Vertex " + i.ToString() + ":\n - StartWidth: " + pLine.GetStartWidthAt(i) + "\n - EndWidth: " + pLine.GetEndWidthAt(i));
I'm looking forward for your help, thank you!
Check twice your Initialize method.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
