.NET
Move a polyline parallel to other polylines
2 REPLIES 2
mdolanVQYAA
140 Views, 2 Replies
I am looking for the best method of moving the red polyline to be completely between the R/W and BOC polylines. Two feet from the R/W to be exact.  I have the R/W polylines green and cyan just to show that there are two of them along the length of the red line.  There could be multiple of the BOC too.
I can find both the closest point on a BOC and RW polylines to any given point on the red line. I can then figure out if it is inside or not. I can figure out where it intersects and stick a new vertex in the red line to keep it inside. That gets it inside but it still looks bad.
Ideally what I am looking for is a way to make the red line have all the vertices of the R/W polylines it runs along.  Ideally the red line would end up looking like this.
Thank you.  Any guidance or examples are greatly appreciated.
2 REPLIES 2
_gile
in reply to: mdolanVQYAA
You should have a look at the Curve.GetOffsetCurves method.
You can also use or get inspiration from the Polyline.Offset extension method from Gile.AutoCAD.Extension library.
Gilles Chanteau
GileCAD
GitHub
mdolanVQYAA
in reply to: _gile
That got me pointed in the right direction. Nice extension library BTW.
AutoCAD Inside the Factory
