.NET
map3d topology
1 REPLY 1
dan.popescu9NZJ8
267 Views, 1 Reply
map3d topology
Can someone post an example of creating a topology polygon from a closed polyline?
I am stuck ...
What I have got so far:
ObjectIdCollection ids1 = new ObjectIdCollection();
then I add the polyline to the ids1
then....
Autodesk.Gis.Map.Topology.Topologies Topos1 = Autodesk.Gis.Map.HostMapApplicationServices.Application.ActiveProject.Topologies;
then the error...
Topos1.Create("aa", ids1, Autodesk.Gis.Map.Topology.TopologyTypes.Polygon);
1 REPLY 1
I'm not sure, but I think you have to use lines (not polylines) to create a topology, so you have to explode the polylines, or recreate the geometry with lines.
Gaston Nunez
Technology Administrators
