Make a command with parameter
Message 1 of 12
Dear All,
I want transmit a outside parameter to CAD, my thinking is like following :
//outside code
class xxxxx
//outside code
string parameter="ParameterToTransmit";
document acdoc.SendCommand("MyCommand ",ParameterToTransmit😞
//CAD command
 [CommandMethod("MyCommand ")]
        public static void MyCommand (ParameterToTransmit)
But i don't know how to make a command with parameter .
Is  it possible to create a command with parameter ?
Or is  it have other solution?
Replies (11)
Message 2 of 12
fieldguy
Message 3 of 12
_gile
You cannot define a command with a parameter (the method attributed with the CommandMethod attribute must return void).
You can create a command with an user prompt and call the command passing ot the input.
        [CommandMethod("MyCommand")]
        public void MyCommand()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var promptResult = ed.GetString("\nEnter the parameter: ");
            if (promptResult.Status != PromptStatus.OK)
                return;
            // Do what you want with the parameter
Then, you can hard code the call to the command with your parameter:
Using AcAdDocument.SendCommand (COM API)
acdoc.SendCommand("MyCommand " + parameter + "\n");
Using Document.SendstringToExecute (.NET API)
doc.SendStringToExecute("MyCommand " + parameter + "\n", false, false, false);
Using Editor.Command()
ed.Command("MyCommand", parameter);
Gilles Chanteau
GileCAD
GitHub
Message 4 of 12
Thanks Sir!
Before i have try this way, it failed, but now it sucess, thank you.
Message 5 of 12
Dear Sir,
May be you are right, but it too trouble for me(i'm not a Professional).
So I accepted solution from Mr _gile . Still very thank you for you help!
Message 6 of 12
foxever
hi, gile
I'm trying to load  some scripts into cad to draw some lines.
Autocad 2018
.NET framework 4.6.1
C#
I've tried to use (with FILEDIA set to 0)
[CommandMethod("BATCHSCR")]
public void BATCHSCR()
    Document acDoc = Application.DocumentManager.MdiActiveDocument;
    Editor ed = acDoc.Editor;
    ed.Command(".script","D:\\123.scr\n ");
    ed.Command(".script","D:\\234.scr\n ");
only commands in the second script has been executed.
and
    string path1 = @"D:\123.scr";
    string path2 = @"D:\234.scr";
    acDoc.SendStringToExecute(".script " + path1 + "\n", false, false, false);
    acDoc.SendStringToExecute(".script " + path2 + "\n", false, false, false);
only commands in the first script has been executed.
Is  it possible to load scripts in one customize command ?
123.scr :
(setq old-osmode(getvar "osmode"))
_osmode 0
_units
2
2
3
4
0
_y
_DIMAUNIT
2
_DIMUNIT
2
_-layer
_n
220427__20220427_2_Report
_c
_red
_s
_POINT
1387480.930000,2623185.220000,0.000000
_POINT
1387602.000000,2623185.220000,0.000000
_-layer
_n
_c
_red
_s
_3DPOLY
(setvar "osmode" old-osmode)
234.scr
_osmode 0
_units
2
2
3
4
0
_y
_DIMAUNIT
2
_DIMUNIT
2
_-layer
_n
220427__20220427_1_Report
_c
_red
_s
_POINT
1387525.930000,2623185.220000,0.000000
_POINT
1387550.000000,2623103.550000,0.000000
_-layer
_n
_c
_red
_s
_3DPOLY
Message 7 of 12
_gile
Using .NET to launch an AutoCAD script is like chasing mosquitoes with a bazooka.
That said, with the Editor.Command() method, you don't have to add a validation after the script file name.
ed.Command(".script", "D:\123.scr");
You can test arguments of Editor.Command() method more simply by using LISP command function directly from AutoCAD:
(command ".script" "D:\123.scr")
Gilles Chanteau
GileCAD
GitHub
Message 8 of 12
foxever
It's a funny  anology.
The scenerio is Program A outputs one script file which contains commands of drawing points and lines for each project.
Script files are placed in different subfolders named with project name.
And I wanna write a plugin to traverse the main folder  to load all the script files into one dwg file.
There is no need of '\n' in parameter when using ed.Command().
ed.Command(".script", "D:\\123.scr");
It works well without "\n".
There is another problem, when using the following codes, the second line will not be executed.
ed.Command(".zoom", "e");
 And there is even no history command (ZOOM E) in autocad command window.
The last command in command window is the last line of script file.
Message 9 of 12
_gile
Does your script file properly ends? IOW is there a validation (space or carriage return) after the (setvar "osmode" old-osmode) LISP expression.
Gilles Chanteau
GileCAD
GitHub
Message 10 of 12
foxever
Uploading scr file is not supported,  file extension change to txt.
This is a  new line after the (setvar "osmode" old-osmode).
This file seems using LF(Unix) as the line break.
Message 11 of 12
_gile
It looks like running a script from .NET is equivalent to call SendStringToExecute passing it the whole .scr file content as argument. This is probalby why it runs asynchronously.
You can try this way;
            string command = File.ReadAllText("D:\\123.scr");
            command += File.ReadAllText("D:\\234.scr");
            command += "_zoom\n_Extents\n";
            doc.SendStringToExecute(command, false, false, true);
Gilles Chanteau
GileCAD
GitHub
Message 12 of 12
foxever
Graceful solution!
It works perfect. Thank u so much.
During the progress, unit setting window will prompt twice. Solved by adding "-" between "_" and "UNITS".
Reference:
AutoCAD help files.
A script can execute any command at the Command prompt except a command that displays a dialog box. In most cases, a command that displays a dialog box has an alternative version of the command that displays Command prompts instead of a dialog box. Most alternative versions of a command start with a hypen (-). For example, use -INSERT instead of INSERT.
