how to set the UCS as respective of two point in C#.net
kite15
kite15
Can any one help how to set the UCS as respective of two point using C# (see the snap).
and return as after running main code .....
Thanks in advance..
kerry_w_brown
Have a look here from Gilles :
https://forums.autodesk.com/t5/net/problem-with-ucs-vectors/m-p/2651940#M18410
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
kite15
Hi _Kdub,
Its works fine, Can you please, more help on this. The UCS icon visibility, also be control. Actually, whenever the UCS icon set to the new position the visibility, of the UCS will be invisible....Smiley Indifferent
Tried:
ViewportTableRecord VpTblRec = tr.GetObject(doc.Editor.ActiveViewportId, OpenMode.ForWrite) as ViewportTableRecord;
acVportTblRec.IconEnabled = false;
not succeed
Thanks in advance
_gile
You can simply set the UCSICON system variable to suit your needs.
Application.SetSystemVariable("UCSICON", 0);
Gilles Chanteau
GileCAD
GitHub
kite15
Thank you .....Smiley Happy
