.NET
Leader with annotation take long time to create
4 REPLIES 4
410 Views, 4 Replies
Hi All,
To create a leader with annotation , I am using below code. Leader and annotation create without any problem. But one disgusting thing is that it took very long time if I use the command first time after opening ACAD. But afterwards when I use the command it execute very quickly. Can any body help me to optimize this code?
<CommandMethod("leadertest")> PublicSubleadertest()
Application.SetSystemVariable("dimldrblk", "_dot")
Dim acDoc AsDocument = Application.DocumentManager.MdiActiveDocument
Dim acCurDb AsDatabase= acDoc.Database
Using acTrans AsTransaction= acCurDb.TransactionManager.StartTransaction()
Dim acBlkTbl AsBlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId,
OpenMode.ForRead)
Dim acBlkTblRec AsBlockTableRecord
acBlkTblRec = acTrans.GetObject(acBlkTbl(
BlockTableRecord.ModelSpace), OpenMode.ForWrite)
Dim mtextId AsObjectIdDim mtxt AsMText = NewMText()
mtxt.SetDatabaseDefaults()
mtxt.Contents =
"first line/sencond line"
mtxt.Location =
NewPoint3d(4, 4, 0)
mtxt.TextHeight = 0.25
mtxt.Attachment =
AttachmentPoint.MiddleLeft
mtxt.SetAttachmentMovingLocation(mtxt.Attachment)
mtextId = acBlkTblRec.AppendEntity(mtxt)
acTrans.AddNewlyCreatedDBObject(mtxt,
True)
Dim acLdr AsLeader = NewLeader()
acLdr.SetDatabaseDefaults()
acLdr.AppendVertex(
NewPoint3d(2, 2, 0))
acLdr.AppendVertex(
NewPoint3d(4, 4, 0))
acLdr.Dimasz = 0.25
acBlkTblRec.AppendEntity(acLdr)
acTrans.AddNewlyCreatedDBObject(acLdr,
True)
acLdr.Annotation = mtextId
acLdr.Dimsah =
False
acLdr.Dimtad = 0
acLdr.Dimgap = 0.25
acLdr.EvaluateLeader()
acTrans.Commit()
EndUsingApplication.ShowAlertDialog("finish")EndSub
Thanks in advance.
Regards
Zakir
4 REPLIES 4
fenton.webb
The only thing i can think is, use StartOpenCloseTransaction and do you really need to call the Evaluate at the end?
Fenton Webb
AutoCAD Engineering
Hallex
I see nothing wrong with your code,
seems it working godd with EvaluateLeader methoud
and without it, see small changes:
        Public Sub leadertest()
            Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("dimldrblk", ".") '"_dot"
            Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim acCurDb As Database = acDoc.Database
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                Dim acBlkTbl As BlockTable
                acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                Dim acBlkTblRec As BlockTableRecord
                acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                Dim arrId As ObjectId = acCurDb.Dimldrblk
                Dim mtextId As ObjectId
                Dim mtxt As MText = New MText()
                mtxt.Contents = "first line\Psecond line"
                mtxt.Location = New Point3d(4, 4, 0)
                mtxt.Attachment = AttachmentPoint.MiddleLeft
                acTrans.AddNewlyCreatedDBObject(mtxt, True)
                Dim acLdr As Leader = New Leader()
                acLdr.AppendVertex(New Point3d(2, 2, 0))
                acLdr.AppendVertex(New Point3d(4, 4, 0))
                acLdr.Dimasz = 0.25
                acLdr.Dimldrblk = arrId
                acTrans.AddNewlyCreatedDBObject(acLdr, True)
                acLdr.Dimsah = False
                acLdr.Dimtad = 0
                acLdr.Dimgap = 0.25
                acTrans.Commit()
            End Using
            acDoc.Editor.WriteMessage(vbLf + "finish")
            ' for debug only
            'acDoc.SendStringToExecute("_ZOOM E ", True, False, False)
        End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
in reply to: fenton.webb
@Fenton: Thanks for your suggestion. I have tried with openclosetransaction , but does not work well. Without evaluate leader it also works well.
in reply to: Hallex
@Hallex: Thanks for your code. I have tired with your code. It reduces little bit time now.
”Boost
