I'm creating a new xref definition and instances on specified layouts (usually just one) in a sideDb:
var path = ...;
var xrefName = ...;
var toCreate = ...; // list of instances to be created
using (Transaction transaction = db.TransactionManager.StartTransaction())
ObjectId newXrefId = db.OverlayXref(path, xrefName);
foreach (var createInstance in toCreate)
var position = new Point3d(0, 0, 0);
var scale = new Scale3d(1, 1, 1);
var newXrefBref = new BlockReference(position, newXrefId);
var xrefDefinition = (BlockTableRecord)transaction.GetObject(newXrefId, OpenMode.ForWrite, false, true);
var layout = GetLayout(db, createInstance.LayoutHandle); // getting layout to add xref to
var layoutBtr = (BlockTableRecord)transaction.GetObject(layout.BlockTableRecordId, OpenMode.ForWrite, false, true);
layoutBtr.AppendEntity(newXrefBref);
layoutBtr.LayoutId = layout.BlockTableRecordId;
xrefDefinition.PathName = xref.Path;
xrefDefinition.IsUnloaded = xref.LoadStatus == LoadStatus.Unloaded;
newXrefBref.Layer = createInstance.LayerName;
newXrefBref.Rotation = createInstance.Rotation
newXrefBref.ScaleFactors = scale;
transaction.AddNewlyCreatedDBObject(newXrefBref, true);
transaction.Commit();
After creating the new xref I try to load all xrefs in the current db. But layout for the newly created xref is null and the function crashes when I use layout..
internal static void GetXrefs(Database db)
var xrg = db.GetHostDwgXrefGraph(true);
for (int i = 1; i < xrg.NumNodes; i++)
var xrgn = xrg.GetXrefNode(i);
BlockTableRecord xrefDefinition = (BlockTableRecord)transaction.GetObject(xrgn.BlockTableRecordId, OpenMode.ForRead);
var xrefInstanceIds = xrefDefinition.GetBlockReferenceIds(true, true);
foreach (ObjectId id in xrefInstanceIds)
var xrefInstance = transaction.GetObject(id, OpenMode.ForRead) as BlockReference;
var layoutBlock = transaction.GetObject(xrefInstance.BlockId, OpenMode.ForRead) as BlockTableRecord;
var layout = transaction.GetObject(layoutBlock.LayoutId, OpenMode.ForRead) as Layout; // layout is null for new xrefs, but works for all others!
transaction.Abort();
return xrefs;
It always works just fine for all other xrefs and if I re-open the file I can use the newly created xref to retrieve the layout as with every other xref...
What is wrong here. Do I need to refresh the db after creating the xref or something? I would prefer not to have to close and open the file again...
Thanks!
