.NET
Is there any way to create a surface or region by point3d array?
8 REPLIES 8
Message 1 of 9
zhongbo.wu
820 Views, 8 Replies
I have a point3d array, and i should create a surface or region by them, but i faild:
-2717.21,-2745.87,-72135
-2717.21,-2745.87,-71835
-2662.88,-2661.92,-71835
-2662.88,-2661.92,-71847
-2711.78,-2737.47,-71854.2
-2711.78,-2737.47,-72115.8
-2662.88,-2661.92,-72123
-2662.88,-2661.92,-72135
First, i create eight lines by these point3d, the use Region.CreateFromCurves() to create region but faild, then i try to create the region in AutoCAD, but it's faild too and show me: Open objects must be coplanar.
Is there anybody can give me some help? thanks a lot!
8 REPLIES 8
Message 2 of 9
Keith.Brown
in reply to: zhongbo.wu
You can create a region from any closed loop.  See this article.
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-NET/files/GUI...
If your point array defines a closed loop, you can create a closed polyline from it and then create the region.
Message 3 of 9
zhongbo.wu
in reply to: Keith.Brown
I have try to draw a 3dpoly by these point3d in AutoCAD, then create region by this 3dpoly, but faild too with a message:1 closed, degenerate or unsupported object rejected.
Message 4 of 9
If points do not belong to the same plane it is impossible to create Region from those points.
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 5 of 9
I know the points must belong to the same plane to create Region, but is there anyway to create a object like region or surface by these points? thanks a lot!
Message 6 of 9
It is impossible create Region with this set of points.
I do not understand what can be done from this set of points in general. This set of points looks like a set of vertical bars.
Expert Elite Member
Message 7 of 9
These data are come from another 3D software, in this software these points can create a polyhedron as shown below. So i'm try to create it in AutoCAD with these points:
Message 8 of 9
@zhongbo.wu
Ok. As far as all points in your set is on one plane - it is possible to create Region.
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
#pragma warning disable 0618
[assembly: CommandClass(typeof(CreateRegion.MyCommands))]
namespace CreateRegion
  public class MyCommands
    [CommandMethod("CreateRegsFromPoints")]
    public void MyCommand() // This method can have any name
      // Put your command code here
      Document doc = Application.DocumentManager.MdiActiveDocument;
      if (doc == null) return;
      Editor ed = doc.Editor;
      Point3dCollection pts = GetPoints();
      Plane plane = new Plane(pts[0], pts[1], pts[2]);
      for (int i = 0; i < pts.Count; i++)
        pts[i] = pts[i].OrthoProject(plane);
      ObjectId plineId = ObjectId.Null;
      using (Polyline pline = new Polyline())
        pline.Normal = plane.Normal;
        Matrix3d mat = Matrix3d.PlaneToWorld(plane).Inverse();
          Point3d p = pts[i].TransformBy(mat);
          pline.AddVertexAt(i, new Point2d(p.X, p.Y), 0, 0, 0);
        mat = Matrix3d.Displacement(pts[0] - pline.GetPoint3dAt(0));
        pline.TransformBy(mat);
        using (BlockTableRecord btr =
          doc.Database.CurrentSpaceId.Open(OpenMode.ForWrite) as BlockTableRecord)
          // plineId = btr.AppendEntity(pline);
          DBObjectCollection objs = new DBObjectCollection();
          objs.Add(pline);
          DBObjectCollection regs = Region.CreateFromCurves(objs);
          if (regs != null)
            for (int i = 0; i < regs.Count; i++)
              using (regs[i])
                Entity ent = regs[i] as Entity;
                if (ent != null)
                  btr.AppendEntity(ent);
    Point3dCollection GetPoints()
      Point3dCollection pts = new Point3dCollection();
      pts.Add(new Point3d(-2717.21, -2745.87, -72135));
      pts.Add(new Point3d(-2717.21, -2745.87, -71835));
      pts.Add(new Point3d(-2662.88, -2661.92, -71835));
      pts.Add(new Point3d(-2662.88, -2661.92, -71847));
      pts.Add(new Point3d(-2711.78, -2737.47, -71854.2));
      pts.Add(new Point3d(-2711.78, -2737.47, -72115.8));
      pts.Add(new Point3d(-2662.88, -2661.92, -72123));
      pts.Add(new Point3d(-2662.88, -2661.92, -72135));
      return pts;
Expert Elite Member
Message 9 of 9
Hi, Alex, thanks for your help, i get it!
Technology Administrators
