.NET
intersection of three spheres (get a solid3d)
1 REPLY 1
1008 Views, 1 Reply
The  first and second figure shows three spheres. What I wanted to customize is to get the common intersection region among the three spheres(seen in third figure). Below is my code.
Imports System
Imports System.Runtime.InteropServices Imports System.Drawing Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.ApplicationServices.DocumentExtension
{code here} Dim bt As BlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead) Dim btr As BlockTableRecord = tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite) Dim its_points As Point3dCollection = New Point3dCollection() its_points = Getcriticalpoints(pt1, pd11, pd12, pt2, pd21, pd22, pt3, pd31, pd32) Dim n_of_itspts As Integer = its_points.Count Dim i As Integer = 0 For Each pt3d As Point3d In its_points Dim ptt As Point3d = pt3d Dim sph As Solid3d = New Solid3d() sph.CreateSphere(rad) sph.TransformBy(Matrix3d.Displacement(ptt - Point3d.Origin)) btr.AppendEntity(sph) tr.AddNewlyCreatedDBObject(sph, True) sphere_ID(i) = sph.ObjectId i = i + 1 Next Dim intersection_points1 As Point3dCollection = New Point3dCollection() Dim intersection_points2 As Point3dCollection = New Point3dCollection() Dim sph1 As Solid3d = tr.GetObject(sphere_ID(0), OpenMode.ForRead) Dim sph2 As Solid3d = tr.GetObject(sphere_ID(1), OpenMode.ForRead) Dim sph3 As Solid3d = tr.GetObject(sphere_ID(2), OpenMode.ForRead) sph1.IntersectWith(sph2, Intersect.OnBothOperands, intersection_points1, IntPtr.Zero, IntPtr.Zero) sph1.IntersectWith(sph3, Intersect.OnBothOperands, intersection_points2, IntPtr.Zero, IntPtr.Zero) btr.AppendEntity(sph1) tr.AddNewlyCreatedDBObject(sph1, True) tr.Commit() end using end sub Private Shared Function Getcriticalpoints(ByVal center1 As Point3d, ByVal rad1 As Double, ByVal height1 As Double, ByVal center2 As Point3d, ByVal rad2 As Double, ByVal height2 As Double, ByVal center3 As Point3d, ByVal rad3 As Double, ByVal height3 As Double) As Point3dCollection Dim result As Point3dCollection = New Point3dCollection Dim line12 As LineSegment3d = New LineSegment3d(center1, center2) Dim line13 As LineSegment3d = New LineSegment3d(center1, center3) Dim line12_dis As Double = line12.Length : Dim line13_dis As Double = line13.Length Dim circ1 As CircularArc3d = New CircularArc3d(center1, Vector3d.ZAxis, rad1) Dim circ2 As CircularArc3d = New CircularArc3d(center2, Vector3d.ZAxis, rad2) Dim circ3 As CircularArc3d = New CircularArc3d(center3, Vector3d.ZAxis, rad3) Dim its212() As Point3d = circ2.IntersectWith(line12) If (Not (its212) Is Nothing) Then Dim point1 As Point3d = New Point3d(its212(0).X, its212(0).Y, its212(0).Z + height2) result.Add(point1) End If Dim its313() As Point3d = circ3.IntersectWith(line13) If (Not (its313) Is Nothing) Then Dim point2 As Point3d = New Point3d(its313(0).X, its313(0).Y, its313(0).Z + height3) result.Add(point2) End If If line12_dis >= line13_dis Then Dim its112() As Point3d = circ1.IntersectWith(line12) If (Not (its112) Is Nothing) Then Dim point3 As Point3d = New Point3d(its112(0).X, its112(0).Y, its112(0).Z + height1) result.Add(point3) End If Else Dim its113() As Point3d = circ1.IntersectWith(line13) If (Not (its113) Is Nothing) Then Dim point4 As Point3d = New Point3d(its113(0).X, its113(0).Y, its113(0).Z + height1) result.Add(point4) End If End If Return result End Function end class end namespace
the debug process will be broken at
with the message
An exception of type 'Autodesk.AutoCAD.Runtime.Exception' occurred in AcdbMgd.dll but was not handled in user code
Additional information: eNotImplementedYet
If there is a handler for this exception, the program may be safely continued.
Can some autocad customization experts help me with this?
1 REPLY 1
Solved.
AutoCAD Inside the Factory
