.NET
Import dwg content into current dwg:
2 REPLIES 2
My_Civil_3D
231 Views, 2 Replies
Hi guys i am looking for a way to import content from a dwg into my current drawing. ive seen several different code to import blocks from a drawing into another which i can do. but it needs to import all content of the model space into the current one at a user specified point. i cant seem to figure this out its way above my skill level if its possible
Civil 3D Certified Professional
2 REPLIES 2
_gile
in reply to: My_Civil_3D
You can use this overload of the Database.Insert method.
Here's an example:
private static void InsertDwgContents(string fileName, Point3d insertionPoint)
    var doc = Application.DocumentManager.MdiActiveDocument;
    var db = doc.Database;
    var transform = Matrix3d.Displacement(insertionPoint.GetAsVector());
    using (var sourceDatabase = new Database(false, true))
        sourceDatabase.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndAllShare, true, null);
        db.Insert(transform, sourceDatabase, true);
Gilles Chanteau
GileCAD
GitHub
My_Civil_3D
thank you sir that worked
AutoCAD Inside the Factory
