I have a problem when activating line thickness in AutoCAD, it only draws the line with a starting and ending point that is not connected
215053ZV64S
215053ZV64S
Community Visitor
Community Visitor
kerry_w_brown
@215053ZV64S
Is this topic .NET code related ?
if so, more information will be required,
if not,
try to re-post in the autocad general forum
https://forums.autodesk.com/t5/autocad-forum/bd-p/706
added:
You will probably need to attach a minimal sample drawing ( and mention the autocad version being used )
regards,
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
