I’m actually getting an error
System.InvalidProgramException occurred
HResult= 0x8013153A Common Language Runtime detected an invalid program.
Source=<Cannot evaluate the exception source>
StackTrace: at Autodesk.AutoCAD.DatabaseServices.Database.get_TransactionManager()
While running this below piece of code
Database sourceDb = new Database(false, true); //Temporary database to hold data for block we want to import
try
sourceDb.ReadDwgFile(dwgPath, System.IO.FileShare.Read, true, ""); //Read the DWG into a side database
ObjectIdCollection blockIds = new ObjectIdCollection(); // Create a variable to store the list of block identifiers
Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = sourceDb.TransactionManager; using (Transaction myT = tm.StartTransaction())
// Open the block table
BlockTable bt = (BlockTable)tm.GetObject(sourceDb.BlockTableId, OpenMode.ForRead, false);
// Check each block in the block table
foreach (ObjectId btrId in bt)
BlockTableRecord btr = (BlockTableRecord)tm.GetObject(btrId, OpenMode.ForRead, false);
// Only add named & non-layout blocks to the copy list
if (!btr.IsAnonymous && !btr.IsLayout)
blockIds.Add(btrId);
btr.Dispose();
// Copy blocks from source to destination database
//IdMapping mapping = new IdMapping(); sourceDb.WblockCloneObjects(blockIds, _database.BlockTableId, mapping, DuplicateRecordCloning.Replace, false); _editor.WriteMessage("\nCopied " + blockIds.Count.ToString() + " block definitions from " + blockToImport + " to the current drawing.");
